LCAudio ZAPFilter - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 19th October 2001, 09:11 AM   #1
Has anyone used the ZAPfilter from LCAudio to replace the opamps in a CD player or DAC? Is this any good? See http://www.lcaudio.com/zapfilter.htm
N.S. Ng
Old 19th October 2001, 10:50 PM   #2
129508 is offline 129508  Norway
N.S. Ng
I have used the Zap filter (initial edititon) with an Rotel RDC 971. I Have also modified with the LCclock. Both mods were positive. It is the second time I do a clock mod and it is worthwhile. It is difficult to describe my observations regarding the ZAP filter, but it became more pleasant and in particular less stresing to listen to music. I have tried other CDplayers not using op-amps in the fitler stage and much of the same effect. Less tireing to listen to the music. Better perspective as well. If you have the money and the patience to mount it, go for it. I would do it again.
Old 20th October 2001, 10:19 AM   #3
Freddie is offline Freddie  Sweden
There's a schematic for the ZAPfilter on their webpage. Why not build it yourself and save some money. I'm sure it can be built for a lot less than $226.
Old 20th October 2001, 08:45 PM   #4
Send a message via ICQ to hatasa
I would like to know where is it?
I cant find the schematic at their website!!
Thanks!
Old 20th October 2001, 08:52 PM   #5
I found it already! Thanks!
Old 31st October 2001, 10:36 PM   #6
sonnya is offline sonnya  Denmark
sonnya's Avatar
Remember one thing : The PCB layout is the half of the design. So be carefull with the layout!
In MK2 the have maked the signal path shorter.
Do you know if the BJT are mathed. What is there parameter they are working after if they match them?
Im not trying to stop you but that's maybe the reason why they publish there designs!?
In the old work they did for High Fidelity in denmark they did mentioned that you would get a higher performance by matching the BJT. Why should they have changed there point of view.
(Sorry about my language)
Sonny
Old 27th December 2003, 11:38 AM   #7
PTSOUNDLAB's Avatar
Hello,
the link is dead. Have you schematic (with PSU) and pcb to give me by mail ? (ptsoundlab@aol.com). I will try it on HK750 cd player.
Thanks.
Pascal.
Old 27th December 2003, 02:14 PM   #8
It's right here: http://www.lcaudio.dk/zf2dia.gif
And here the PCB layouts:
Old 27th December 2003, 02:47 PM   #9
PTSOUNDLAB's Avatar
Thank you very much !
Best Regards.
Pascal.
Old 24th March 2013, 09:03 PM   #10
Anyone knows what exactly types of smd transistors was used in mk2 ?
only 2fs, 4fs, br and fr printed on them, cant find anything in web basing on this.
Zapfilter vizion Digital Source 0 25th May 2008 03:24 AM
WTB Zapfilter iwok Swap Meet 0 10th December 2007 12:48 AM
WTB ZapFilter markmelheim Swap Meet 0 20th October 2005 08:29 PM
LCAudio Softstart chrisb03 Class D 4 11th April 2005 06:54 AM
experiences with the ZapFilter 2 mm2 Digital Source 0 30th March 2005 09:15 PM
Copyright 1999-2017 diyAudio
