Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th January 2007, 11:17 PM   #1
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Default Help with Audio Sector NOS DAC
Hey All,
I just finished up the Audio Sector NOS DAC and it's not working. It didn't blow up and nothing got hot. That's good, but all I'm getting out of it is 120hz hum.
Any ideas what to check out first?
I'm using the green board with transformer off the board.
Vince
Old 12th January 2007, 11:33 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Did you install the jumper on CS8412?
What are the voltages after all 4 regulators ?
How did you connect RCAs output, any pics?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th January 2007, 01:46 AM   #3
vdi_nenna's Avatar
Hi Peter,
I got these voltages:
Facing reg flat side-
U1- 2.74-0-2.79
U2- 2.76-0-2.79
U3- 2.79-0-2.79
Voltage after rectifier coils
L1- 4.41v
L2- 4.54v
I suppose these are all low? These should be around 8-9v after the regs.
The transformer secondaries 9v in parallel. But I have a feeling I don't have the transformer wired right.
Is there orientation on J1 and J2?
Old 13th January 2007, 01:48 AM   #4
vdi_nenna's Avatar
These are the best my old digital camera can do at close range.
Old 13th January 2007, 01:57 AM   #5
vdi_nenna's Avatar
Last pic...
Old 13th January 2007, 03:44 AM   #6
U1- 2.74-0-2.79
U2- 2.76-0-2.79
U3- 2.79-0-2.79
L1- 4.41v
L2- 4.54v
The voltage after regulators should be 5V and 8V on DAC.
Both secondaries need to be used here, so they cannot be connected in parallel. One secondary powers input buffer and receiver and connects to J2, the other powers DAC chip and connects to J1. The voltage after rectifiers is approx 12V, after ressitors approx 11V. You have 2.5V which is way too low.
There is no orientation on J1 and J2.
www.audiosector.com
Old 13th January 2007, 01:55 PM   #7
vdi_nenna's Avatar
I rewired in parallel and I got:
5.05-0-12+ on U1-4
No hum, but no sound either.
On SN75179 Pin 1 is 5v.
On TDA1543 Pin 5 is 4.43v. Is this too low for digital?
Can't tell on CS8412.
Old 13th January 2007, 03:27 PM   #8
It looks like you got right the PS in the receiver section, however the supply voltage on TDA1543 (U7) is too low. You need to get 8V on pin 5. The unregulated supply here is made the same way as for the receiver, so you should be able to find what went wrong comparing voltages in both sections.
Just make sure the secondary from transformer (connected to J1) is separate from secondary connected to J1 and has similar AC voltage rating (9V or so).
www.audiosector.com
Old 13th January 2007, 05:44 PM   #9
vdi_nenna's Avatar
I think I found the problem. I ordered all AN8005s! U4 is a AN8008! DETIALS!
Thanks for your help!
Vince
Old 13th January 2007, 05:50 PM   #10
But 4.43V after U4 is still low, even for 5V regulator. What is the voltage before regulator?
The DAC will work with 5V, although not as good. Contact me through PM and I will ship you 8V regulator.
www.audiosector.com
Audio sector gainclone. dome406 Chip Amps 33 31st May 2010 02:12 AM
FS: Peter Daniel Audio Sector NOS dac $250 jrebman Swap Meet 1 7th March 2009 10:27 PM
audio sector- lm4780 kit richyrich212t Chip Amps 1 25th August 2007 10:14 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 01:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 05:49 PM
Page generated in 0.09770 seconds (81.33% PHP - 18.67% MySQL) with 11 queries
