| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a MF A3.24 DAC with a failure of the coaxial digital input. The Optical input work OK and the DAC works and sounds great. My only problem is the coaxial input. Anyone has experienced this problem? Can you recommend how to approach this repair? If someone on the forum has the schematic for the A3.24 DAC that would be great. Thanks, Ronen
ronenash |
#2 |
I would guess that the problem is the IC10 the DS266L532CM as it it the only active device that would stop the coax input as the optical comes in after this.
Also are you sure it's not the coax output of your transport before you start ripping into this? Cheers George |
#3 |
I have the same unit. Sometimes the signal fails to "lock" unless one cycles power. As you probably know, the bright blue LED in front indicates signal lock. Is it on?
If cycling power does not fix the problem, you'll need to get inside the unit to troubleshoot. For that you'll need a #10 Torx security wrench/bit. As far as the schematics ... good luck. I've tried to obtain these myself but this company -- like many "high-end" audio/video companies -- are highly protective of their designs and only supply circuit schematics to official dealers or repair facilities. (Check MF's web site for more info on this.) Frankly, my disgust with companies like this -- and all the high-end magazine kiss-*** politics that promote their so-so over-priced products -- is why I pretty much went DIY. It's way less $, way more fun/rewarding, the camaraderie/support (via DIY forums) and open availability of info and schematics is unparalleled, and (IMO) the end product actually performs better. An example of this is mod'ing one of the latest Toshiba CD/DVD players (see this page for more info)). For about $90 -- that includes the price of a new player ($40), readily-avail. schematics ($20), and a few upgrade parts ($30: op-amp, rope caulk, etc.) -- I have attained Red Book playback that sounds better than the A3-24. I also have a decent DVD player, whose performance also improved via the mod. And I don't need a special $10 bit to get inside it! Okay … I'm stepping off my soapbox, now |
#4 | |
Also this dac is very good sounding out of the box, and if you do my dc coupling and I/V mods also in previos threads, it is so far unbeatable. Cheers George |
#5 | ||
#6 | |
diyAudio Moderator Emeritus
It's only audio |
#7 | |
I ended up getting this Security Torx Fold-Up Keys Sets , which actually cost more than the $10 I noted earlier. I think the $10 tool was/is avail at Lowe's or Wal-Mart. |
#8 | |
- In the aforementioned thread you wrote "put a digital multimeter on the output and earth". Do you mean put one lead of meter on the output JACK (hot side)? - Would you recommend this same mod (one that uses 5k cermet mini pots) for DACs in general? Thx |
#9 | |
The IC change is for the I/V stage which changes out the two NE5532's for 4 AD825's smd. The DC coupling mod greatly enchances the sound, as does the I/V IC mod to a lesser degree. Cheers George |
#10 | |
I'm not sure if you addresed my first question so I'll repeat it again: In the aforementioned thread you wrote "put a digital multimeter on the output and earth". Do you mean put one lead of meter on the output JACK (hot side) and the other on ground? |
| Musical Fidelity B1 amp - repair and small mod | tuck1s | Solid State | 0 | 27th March 2009 02:56 PM |
| Musical Fidelity A5 | sakis | Solid State | 4 | 17th October 2008 02:00 PM |
| musical fidelity B1 | mcberta2 | Solid State | 0 | 31st December 2007 10:31 AM |
| Musical Fidelity CD Pre 24 | devron12 | Solid State | 5 | 7th January 2006 06:01 PM |
| musical fidelity repair | mistamovie | Solid State | 14 | 3rd March 2005 11:19 AM |
| Page generated in 0.12314 seconds (82.06% PHP - 17.94% MySQL) with 11 queries |
