| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've had the cover off of my new universal player in anticipation of installing a new precision clock and after a brief look around the only crystal I could find was on the main audio board and was marked 12.288/32. I've since received a copy of the service manual for this player and the first instance I can find of any sort of clock is labelled 12.288 Mhz. This causes me to pause and take note that all the previous replacement clocks I've seen do not mention this frequency. Thoughts anyone?
![]() Regards, Dan |
#2 |
Hello Dan
Yes this is indeed a 12.288 MHz player. Best regards Lars Clausen
www.newclassd.com |
#3 | |
Lars,
None of your Audio Reference Clocks carry this frequency: Quote:
Regards, Dan |
#4 |
I have already ordered 12.288 MHz crystals, they should be available shortly.
www.newclassd.com |
#5 |
Hi Dan,
This is probably for your DV7600… DSP chip uses 12.288MHz frequency to generate various other frequencies for different sections in a DVD player, like video section, transport servo section and audio replay from DVD-A, CD (and SACD?) disk section(s). This chip contains dividers / multipliers and it also does clock signal squaring, buffering and clock distribution. External 12.2888MHz clock source would help a lot. If you can't find the clock with 12.288MHz crystal, you can buy any clock and replace the stock crystal with a 12.288 crystal you removed from your DVD player. There is one important thing to check, PIN 127 clock signal amplitude - use a CRO with probe setting at 1:10 to prevent clock signal load, which could give you funny signal shape... It won't be bigger than 3.3V (!!!) so you'll need to choose the external clock accordingly! Good luck, Boky |
#6 |
Just to let you know, we can now deliver 12.288 from stock.
www.newclassd.com |
#7 |
What kind of DVD video picture quality improvement can be expected from changing out the clock osc to one of your units. Thanks
Walter |
| Clock distribution in CD player | Sebba | Digital Source | 0 | 3rd March 2008 09:20 PM |
| PSX clock for CD Player use | pozo1992 | Digital Source | 6 | 10th November 2005 01:21 PM |
| CD Player with a WORD CLOCK out? | JP Audiophile | Digital Source | 0 | 3rd August 2005 03:26 PM |
| location of clock in panasonic s35 DVD player | timsch75 | Everything Else | 0 | 9th January 2005 05:24 PM |
| Clock for CD player.. | Freddie | Pass Labs | 1 | 23rd December 2001 06:37 PM |
| Page generated in 0.08007 seconds (79.53% PHP - 20.47% MySQL) with 10 queries |
