Datasheet needed - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st January 2003, 03:17 PM   #1
tortello's Avatar
Question Datasheet needed
Hello,
I need the CXA 1081 Sony IC datasheet.
I tried at the Sony's website, but this part documentation is not avaible online.
There is someone which can sent me something?
Marcello
Old 1st January 2003, 04:29 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
Hello Tortello,
I don't have the datasheet but if you are searching for the chip itself I have one CXA1081S ( Dil format ) left.
Jean-Paul
It's only audio. Member of the non modular PCB design committee
Old 1st January 2003, 04:41 PM   #3
jean-paul's Avatar
In one of my datasheets I found this info, maybe it is of some help. I have the same scan in 600 dpi but you have to leave a mailadress where I can mail it to.
Old 2nd January 2003, 08:19 AM   #4
tortello's Avatar
Hello Jean-Paul,
thanks for your reply.
I'm not very skilled in CD-players fixing, I think that the failure is here trying to freeze the suspect components:
when I made this on the CXA1081, the player began to read the disc, when I heated it again, the player stopped.
Have you ever had any experience about this part's failure?
Thanks again and happy new year!
Marcello
Old 2nd January 2003, 08:56 AM   #5
jean-paul's Avatar
Happy new year to you too ! No, I don't have seen defective CXA1081S's but that doesn't mean a thing.
If you freeze it with spray and it plays I would call this IC defective. Did you freeze resistors as well and did you resolder all joints ? Is so, order a new chip.
Old 2nd January 2003, 09:47 PM   #6
tortello's Avatar
Hi Jean-Paul,
thanks for your advices.
I' ve just ordered the IC to a local shop (I hope he'll be able to find it). I'll let you know something about.
All the best
Marcello
Old 28th January 2003, 05:27 AM   #7
tortello's Avatar
Hello Jean-Paul,
Sony Italy was not able to give me the correct (old 30 pins) DIL version.
Could you please send to me your IC?
Marcello
Old 28th January 2003, 06:59 AM   #8
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
What you are looking at appears to be an RF chip, also commonly called a "read-channel processor". From the diagram, it doesn't look like a particularly modern part. In any case, it is probably a relabelled part made by another manufacturer, as Sony commonly does. Most likley TI, since they make a good deal of the world's RF chips. The chip is probably out of production for some time now, so your best bet to find a replacement is likely to be in other scrap equipment (that is, if you don't get one from jean-paul ).
Anyway, the proper operation of this chip will depend to a large extent on a number of passive components external to the chip itself, usually in it's immediate vicinity... little resistors and caps. Temperature variations could be causing component values to change or intermittent shorts (eg bad solder joints) to open and close. As previsouly mentioned, check all the solder joints, and also try checking the quality of the conections between this chip and the laser pickup head.
- Chad.
Old 28th January 2003, 07:29 AM   #9
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hello tortello
If the player isn't fixed already...
What type is the player?
It rarely happens a chip is broken.
Most cd-players i repair give problems with the laser unit. First i clean the lens , if the prob is still there i replace them; 95% success. What laser unit is in there? KSS210? How old is it? Can you measure the RF-signal?
/ Hugo cleaning them all the time
Old 28th January 2003, 09:05 AM   #10
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb CXA1081
Hi tortello,
From my experience as repairtechnician I learned these chips seldom brake down.
I agree with Hugo (netlist) that replacing the laserunit is a reoccurring solution.
Datasheet of CXD1165P needed beauty_divine Digital Line Level 0 29th August 2008 03:41 PM
Sony CXD2510Q datasheet needed Johnpang Digital Source 1 18th September 2006 04:06 PM
UPC2506v Datasheet Needed hotwaterwizard Chip Amps 0 4th March 2004 01:21 AM
sony CXD2510Q datasheet needed hifi Digital Source 1 11th September 2003 06:46 AM
ROHM Transistors datasheet needed grataku Solid State 1 30th May 2001 08:10 PM
Copyright 1999-2017 diyAudio
