| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Just thinking about a DAC project - nothing special so far, with one exception: I'd very much like to have an I²S input, directly attached to the DAC chip. I have played with LVDS driver and receiver circuits, there's no problem to transfer I²S data between a CD drive and a DAC with this system.
Since I won't rely on this proprietary format alone, there has to be some common SPDIF input receiver as well, most probably CS8416 these days. The question is: How to switch between the two interfaces? For the LVDS receivers it's easy, their outputs can be disabled. But what's with the CS8416 (in hardware mode)? I didn't find any possibility to disable its ouputs, the only possibility I see is to force it into a permanent reset state when it is not active. Will this work? |
#2 |
One possibility is to buffer the outputs of the CS8416 with a 74XX125 quad buffer with tristate outputs.
Or you could use a 74XX257 quad multiplexer to select the signals. Regards, Florian |
#3 |
I had thought about buffers/multiplexers, but I want to avoid additional jitter sources if possible.
| CS8416 vs CS8414 | cbriere | Digital Line Level | 1 | 5th January 2009 09:13 PM |
| FS: Cs8416-cs | A'af | Swap Meet | 1 | 31st March 2008 03:44 PM |
| DIR9001 Vs CS8416 | bou | Digital Source | 1 | 13th June 2007 12:26 PM |
| CS8412 or CS8416 | pigoia | Digital Source | 4 | 12th April 2007 09:03 PM |
| Cs8416 | macsaif | Digital Source | 0 | 5th July 2005 07:03 PM |
| Page generated in 0.06094 seconds (73.96% PHP - 26.04% MySQL) with 11 queries |
