| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I run digital direct and digitize any analog signal and run it mercilessly through some behringer stuff. (SRC/DEQ/DCX 2496)
So far so good - to my ears at least. I acquired a new sample rate converter, because I had to troubleshoot some problems. What happens - at 24/96 upsampling on some cd's i get some nasty clicking sounds. So, lets try an external wordclock - got one from hosa, works 44.1, 48kHz and double the base rates. To my astonishment, with the external wordclock at 96 kHz, even digital signal from satellite receiver starts clicking - never done that before -, and cd's are even worse than before. Back to 88.2 - no problem. Also there is no problem whith external or internal clocksignal when switching to analogue input at the src. Asked the behringer guys, and they mumbled something about 96kHz too high resolution, so switch back a notch. I am not quite satisfied with that answer - does anybody have an explanation? |
#2 |
What are you using the external clock for? The sample rate converter?
I think you need to come up with some schematics/pictures of your setup. How can you have an analog input on a src (sample rate converter)? |
#3 |
SOURCES - SRC - DEQ - DCX - Volume control - AMPS
The behringer SRC works both as a sample rate converter and a dac/adc. It has an internal clock, which works fine except on some cd's - it doesn't. That is why I tried an external clock to see if something changes - on 24/96 upsampling only I have the problem, not on 24/88.2 omebody in another forum mentioned that on bad sectors on a cd the higher sampling rate could interfere with the error correction? Dn't know if that is possible. |
| amplifier clicking in and out of protection | theblackknight | Solid State | 26 | 7th November 2009 03:31 PM |
| Adcom GFA 535 Clicking on Power Up and Down | YammerBoy | Solid State | 1 | 14th June 2009 10:12 PM |
| Power supply clicking won't start | argonrepublic | Power Supplies | 11 | 24th April 2009 04:29 AM |
| nakamichi cd 700 clicking sound plz help !! | anton-sa | Car Audio | 3 | 22nd December 2008 05:10 PM |
| Intermittant Clicking | dsavitsk | Tubes / Valves | 16 | 28th January 2007 06:55 AM |
| Page generated in 0.06904 seconds (70.43% PHP - 29.57% MySQL) with 10 queries |
