Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd January 2007, 07:06 PM   #11
cviller is offline cviller  Denmark
cviller's Avatar
The plain Hitachi LCD's are a breeze!
I have made a small board for my at89s51 so I can play around with the displays. So far I'm not very lucky. I have tried both four and eight bit mode, but I don't seem to be able to write anything interesting. If you have some advice on what init signal I should send I would be very happy!
I have connected two different displays. One is 2x16 and the other is 3x16 - both with 5x7 letters. I am able to make it show some junk but no letters.
I'll wait with the grand micro controller board until I get the lcd and receiver->dac chain working using SPI. This way I'll have a more clear picture exactly what I need and I'm not in a hurry since I have the at89s51 running on a piece of scrap pcb.
I'm also working on the board for cs8416. I have used this chip several times, but only in hardware mode. I would share the spi signals "clock, input and output" between dac and spdif receiver and route "chip select" individually to each board. Now the problem is the cs8416 uses 3.3V logic when connected to the Texas devices and my micro controller uses 5V logic. I guess it would be wise to use a level shifter. Any suggestions for level shifting?
I have found this:
http://www.standardics.nxp.com/suppo...df/an97055.pdf
(summary: A n-mos per signal with gate connected to vdd(3.3) and pull up resistors on both sides. Source connected to 3.3 end of signal and drain to 5V end.)
Is that the way to go?
Samsung 1602VFD For CDROM Controller & Remote Volume Controller slowgay Swap Meet 2 22nd November 2008 02:44 PM
Micro Jacks and Micro Pins for board-board connection jazzist Parts 1 12th May 2008 03:02 PM
Modular NOS DAC dsavitsk Digital Source 1 14th June 2006 03:31 PM
Project - Universal CD Controller? lgreen Car Audio 1 22nd September 2003 12:20 AM
digital filter using pic micro controller vish_zn Digital Source 16 20th March 2002 08:47 AM
Page generated in 0.06581 seconds (70.18% PHP - 29.82% MySQL) with 11 queries
