| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a whistling tone of about 4 kHz with my TentDac.
Regulator U23 has a sinusoidal signal of 20mV pp and a period of 1.5 µsec. Need help please. |
#2 | |
Jan/Jeff/Jos did you try to contact Guido tent? Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
I would write "whistle" and not "whisple"
Sorry. |
#4 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 | |
Hi JP The 1.5uS may stem with the speed of the phase comparator. U23 however feeds the reclocking logic. Is the whistle tone audible at both channels ? best |
#6 | |
I made a mistake with T=1.5 µSec, time base was set to x2. T is 3 µSec. The volume of the tone changes regulary and is lower when set to PAUZE and STOP. Loudest when playing music. I use the pcm1704 adapter, but changing this for a pcm1702 adapter from Linn has the same result. I'll try to observe the results so I can give more to the point data. Any recommandation what I have to test? Kind regards. JP |
#8 | |
Thanks. JP |
#9 |
Report: (att Guido and Peranders and others)
1 The tone comes from the RADIO input of my Quad 44 and not from the DAC. My mistake, I used Radio and not the CD input. Maybe oscillation? All is n ormal with the tuner as source on this input. 2 The signal on the regulator U23 is a mystery for me. Can this affect the sound quality of the DAC? 3 The noise level on the direct output after the filter is about 8 mV pp. Measured with an old oscilloscope. Mostly hum and noise. Is this value good? The noise is good detectable when playing loud and then the CD player set to PAUSE. Help is welcome. JP |
#10 | |
2: I have no DAC available here curently, so cannot verify, but will do once my own DAC i back best |
| mdc-800 tone arm | waynzworld | Analogue Source | 7 | 25th October 2007 12:19 AM |
| Freaky Whistle in Guitar Amp | Trout | Tubes / Valves | 47 | 9th January 2006 05:42 PM |
| dog whistle | peterr | Tubes / Valves | 11 | 22nd November 2004 10:30 AM |
| Need tone arm help | woody | Analogue Source | 4 | 18th June 2003 12:21 AM |
| Page generated in 0.10417 seconds (77.05% PHP - 22.95% MySQL) with 10 queries |
