| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
A couple of weeks ago I took a long walk down memory lane and installed DOS on an old computer I had laying around. Back in the days (1992 or something) I had a computer with a sound device normally known as a Covox. Actually the Covox Speech Thing was a commercial product but since it was so easy to build you could pick one up for a couple of bucks almost anywhere.
Some explenation to what a covox basically is. In the early pc days sound cards were fairly expensive for a 13 year old kid so someone designed a rather nifty little DAC you could connect to the printer port of almost any computer at the time. There are a few different versions but the main idea is to make use of the 8bit resolution of the printer port output and connect them to a resistor ladder and the to the amplifier. I thought I would like to try it with a ready DAC chip so I ordered a couple of AD558 samples from Analog Device. (Thank you very much) http://www.analog.com/en/prod/0,2877,AD558,00.html I assembled everything on a pcb one late night a few days ago but there is a problem. When I tried it out I got sound but it sounds HORRIBLE. Some kind of extreme distorsion. The DAC has 2 voltage output ranges but I am 100% sure I am using the 2.56V range. I have also connected a potentiometer between mu covox and amplifier just to make sure its not input distorsion in my amp. I think the problem might be that the DAC does not have a symmetrical voltage output but wouldnt that be the case also with just resistors on the printer port??? Any good ideas where I should start? |
#2 |
Did some more measurements today and something is VERY weird. I tried to reverse all 8 bits bit that made it even worse :S Any ideas what I should do?
#3 |
Forgot to give you some info. The test signal is a 440Hz wave file 22.050kHz 8bit mono, and the scope is set at 1V/div and 0.5msec.
#4 |
invert only msb
#5 |
Great idea. I'll give it a try as soon as I can. Thanks.
#6 |
Solved the problem late last night. As it turns out I had connected the 7th bit to the input of the 8th bit, and the 8th bit was not connected at all. Discovered the problem with a software that allowed be to turn on and of every bit individually. Now it works great and plays music the way it should. Ahhhh how I miss the good old days.
| Should I bother bringing these back to life? | lowpoke | Multi-Way | 4 | 15th March 2009 12:37 PM |
| Bringing Marantz PM55 up to SE spec | harrygrey382 | Solid State | 3 | 16th June 2007 06:39 PM |
| Bringing the truth... | roibm | The Lounge | 34 | 19th April 2004 06:15 PM |
| Dantax century | Luckyme | Multi-Way | 0 | 14th March 2004 03:51 PM |
| Help bringing up Aleph2. (Smoke) | harvardian | Pass Labs | 24 | 3rd February 2003 09:28 PM |
| Page generated in 0.08049 seconds (73.80% PHP - 26.20% MySQL) with 11 queries |
