Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Help me mod Philips CD960
Old 8th December 2006, 11:58 AM   #1
@lf is offline @lf  Bosnia and Herzegovina
Default Help me mod Philips CD960
Here is shematics for analog out:
Old 8th December 2006, 12:06 PM   #2
Here is shematics for modded analog out I found on the internet:
Old 8th December 2006, 12:09 PM   #3
Here is another shematics for analog out:
I need opinion/explanation of this mods before I start desoldering.
Does anyone have any other suggestions for modding analog out?
I will post power supply shematics also.
Old 8th December 2006, 12:26 PM   #4
poynton is offline poynton  United Kingdom
poynton's Avatar
Hi
Neither will work !
Andy
Old 8th December 2006, 08:53 PM   #5
Hi
Neither will work !
Andy
There is mistake in first shematic. Here is correct one.
Any other who can comment these mods or have suggestion for different approach?
What about 14 220n caps on TDA1541A?
Old 8th December 2006, 09:15 PM   #6
I removed 100uF cap and CDP has much more detail and better bass now.
Old 9th December 2006, 02:55 PM   #7
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
You could try to remove the 2,2n slew rate limitation cap.
And the 22n cap on the output.
The first resistor with red X is for DAC current offset compensation, removing it will cause DC offset on output if 100F is removed.
The middle part is the analog filter, gives lot of HF when removed because of 4x oversampling.
Try change the 14 decoupling caps for higher quality/value,
1k78 I/V resistor for better quality,
better op amps + better decoupling caps.
Upgrade to S1 chip + SAA7220B perhaps.
Old 10th December 2006, 02:26 PM   #8
Which one? (see red circles in shematic)
Higher value is =
I have at hand only 100n WIMA MKP
[/QUOTE]
Do you have any reccomendation (KIWAME, VISHAY)?
I have AD825 OP AMPS. Any other/better choice you can reccomend?
cap.
I have SAA7220B, S1 and S2 chip. I replaced TDA1541A with S1 (for S2 I'm not sure is it original or not) and player has more detail and better sound now.
THANK YOU for your replay
Old 10th December 2006, 02:31 PM   #9
correct one
Old 10th December 2006, 02:35 PM   #10
Bernhard's Avatar
Originally posted by @lf
[B]
Which one?
The 2,2n below the I/V resistor.
[B]
Maybe just make sure they are not magnetic.
Or Vishay ?
Help me mod Philips CD960Hide this!Advertise here!
Help with Philips CD960 muizel Digital Source 14 17th August 2017 02:55 PM
Philips cd960 problem muizel Digital Source 0 28th October 2006 12:03 AM
Philips CD960 diyman Digital Source 0 1st November 2005 01:50 PM
Buttons for Philips CD960 Bernhard Swap Meet 0 13th November 2004 08:45 PM
