Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2006, 10:15 PM   #1
darkfenriz's Avatar
Default Help me design a SPDIF reclocker, preferably based on 74hc4046
Hi
I want to design a reclocker that is based on typical TTL IC's and a very basic one. I do not nessesary need low jitter, rather a real PLL reclocking based on data bits, not preamble (like in cs8414 or so..)
I am not sure what is the way to amplify SPDIF signal to TTL level as well as wheather I need a frequency divider in PLL.
Please help!
best regards
Adam
Old 8th December 2006, 12:18 AM   #2
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
To bring SPDIF to TTL the easiest way is to use 74HCU04 inverters AC coupled at the input with 100n CAP then bias the HCU04s into linear operation by using an input resitor of say 1K and a feedback resistor of 10K. (you may need to optimise these values) Cascade two or three of these to bring the signal up to TTL levels.
The U in HCU04 means they are unbuffered and hence can operate as linear amplifers.
As for using the HC4046 it is well documented in the data sheet first read this. You should be able to set the VCO to operate at 256x Fs (11.2896MHz) and I would use phase comparitor 2. Its the most difficult to get working well but it is much lower noise than the others.
You will need to use an external divider to match the VCO freq to your incomming data frequency. ( I think this is 2.8224MHz approx for SPDIF but I could have remebered it wrong i.e you need to divide by 4)
Not quite sure why you want to do this but this should give you a very jittery but phase locked clock.
Andrew
Old 8th December 2006, 11:23 AM   #3
darkfenriz's Avatar
Thanks Andrew
That's exactly what I want: low data-induced jitter rejection to check transmission media impact on sound.
regards
Adam
Old 8th December 2006, 12:33 PM   #4
SSassen is offline SSassen  Netherlands
SSassen's Avatar
I'm sure you already came across the following, which basically allows you to hit the ground running.
Philips design software 74HCT4046/7046/9046
http://www.standardics.nxp.com/support/pll/pll.zip
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
Acception without proper examination equals religion
Condemnation without proper examination equals prejudice
Old 14th December 2006, 10:16 PM   #5
darkfenriz's Avatar
That's how I'd imagine this reclocker to be.
C1 probably will need adjustment.
Please comment.
regards
Adam
Old 14th December 2006, 11:06 PM   #6
Originally posted by darkfenriz
Please comment.
You have actually read the SPDIF specification ?
Old 14th December 2006, 11:19 PM   #7
darkfenriz's Avatar
By AES? Not whole, why do you ask?
If something's wrong, than well, If you could help, this ehhmm... would be some kind of ? helpful...
Old 14th December 2006, 11:48 PM   #8
There are minor design errors and there are Tacoma Narrows sized errors. Your error is so fundamental, the only thing I can say is read and understand the specification
Old 15th December 2006, 09:23 AM   #9
darkfenriz's Avatar
Read the specification, datasheets of receivers and Hawksford's publication.
No clue...
Old 15th December 2006, 10:09 AM   #10
No clue...
The datastream has the clock embedded in it, is biphase mark encoded and uses code violations to define the channel boundaries.
Which particular edge do you plan to lock to and what do you intend to use as a reference ?
Die, SPDIF ! Design of the Ethernet DAC peufeu Digital Source 212 18th May 2012 09:25 PM
dddac1543 mk2 ** modular design ** USB & SPDIF input ** dddac Digital Source 69 21st July 2011 08:18 AM
DAC design | First step: SPDIF receiver webzeb Digital Source 9 6th February 2006 10:11 PM
HQ USB to SPDIF Circuit Design??? fastcat95 Digital Source 10 6th July 2005 12:55 AM
Page generated in 0.09827 seconds (82.60% PHP - 17.40% MySQL) with 11 queries
