| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
Some time ago I built a simple I/V stage for my DIY TDA1541 DAC. That stage used a 47 ohm resistor for I/V, followed by a Sowter 8347 step-up transformer. It performed well, but output voltage was much lower than usual and high output impedance made interfacing critical. Now I am planning to lower the I/V resistor (in order to reduce distortion) and add an op-amp (OPA627) gain stage at the output which, hopefully, will also lower output impedance. I am not an EE, so I would appreciate opinions from you skilled friends. Best regards. Paul please look at the attached schematic |
#2 |
The datasheet do recommend the output voltage to be no less than 25mV. People suggest that the output current is around 1mA so less than 25ohm i/v resistor would do. (one of my friend prefer 39R instead) But then you need around 1:100 gain to get 2V out.
OPA637 is another option when gain>5 is required. Correct me if I'm wrong but this circuit yields 180deg out of phase. I'm nobody in electronic world either.
| FS: Philips CD931 with internal TDA1541A DAC & JFET STAGE | cartman | Swap Meet | 1 | 9th April 2011 06:49 AM |
| About discrete I/V stage circuits for a TDA1541A dac | gaetan8888 | Digital Line Level | 5 | 11th December 2010 07:28 PM |
| How to connect diyparadise i/v stage to tda1541A | Chilli6565 | Digital Source | 4 | 12th February 2009 06:31 PM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Your Favorite Output Stage for TDA1541a ? | riotubes | Digital Source | 1 | 22nd October 2006 01:46 AM |
| Page generated in 0.05944 seconds (69.94% PHP - 30.06% MySQL) with 11 queries |
