Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Denon DCD 1520 not recognise some disc
Old 28th November 2006, 01:29 PM   #1
stoozo is offline stoozo  Australia
Default Denon DCD 1520 not recognise some disc
15 years old Denon DCD 1520 CD player refuses to play some discs. Has been a continuing problem for 10 years but getting worse - can't read more and more discs!
Service agent in distributor here (Sydney) offered to replace laser pick up assembly KSS-151A (Sony?) but did not guarantee outcome. I knocked back the offer.
Reading up some material on the net, I started to open up the machine. Found that for 'playable' discs, the motor spins the disc clockwise and reads the directory track. For 'unrecognised' disc, it actually spins it anti-clockwise for about a revolution or so, stops with a click sound, tries again for a few times, and displays 0's on the front panel.
I have tried cleaning the lens, no results.
Would anyone please tell me what's wrong?
Old 29th November 2006, 03:18 PM   #2
stephensank is offline stephensank  United States
This is a typical failure pattern for the KSS151. I would be 98% sure that a new laser would cure the problem.
Old 30th November 2006, 11:07 AM   #3
Thanks, Stephensank.
The price for Denon's local agent to replace the laser assembly was AUD350, with which I did not proceed.
Instead, I have now bought a new Denon DCD-700AE for AUD560. Have I done the right thing? The new machine is brand new technology, I suppose, but weighs five times less, very light and flimsy built. The sound is alright, quite like the old DCD-1520.
Any suggestion how to dispose of the old machine? I am still using it to read some odd discs that it plays, on my second sound system. It would be nice to find a cheaper way to fix it.
Stoozo.
Old 1st December 2006, 04:08 AM   #4
rejithcv is offline rejithcv  India
Send a message via Yahoo to rejithcv
This could be an allignment problem. Most of the drives have this prob with no chance of repair. Replacing the lens system will solve them..
Old 1st December 2006, 06:38 AM   #5
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I have the same problem with my DCD1520 but this is a process, the laser gets weaker and weaker. Now it's impossible to play CDR's and some bought CD's. I have tuned up the laser once but the machine is so old so I'll let it rest and buy a new one, especially since my daughter has damaged a button.
A new laser costs in England approx. 49 GBP so if you can fix it yourself it might be worth it. I think I have seen a place for half the price also but I'm not sure.
I Sweden I have read about people that have fixed it pretty easily.
Suitable keywords for google "Laser KSS151A DCD1520"
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 10th December 2006, 11:26 AM   #6
Thanks, guys
I believe I have done the right thing. The new DCD700 is good enough.
I'll keep the old machine to read whatever it can read until some day I come across a replacement laser. A new laser component costing AUD150 is out of question - too dear.
Old 12th December 2006, 01:47 AM   #7
Extreme_Boky is offline Extreme_Boky  Australia
My experience with DENON CD and DVD players, when it comes to their ability to read low reflectivity disks, is very bad. The units come of assembly line marginal at best. It may be harsh to characterise all DENON players as being marginal – but this is what I have found with 3 DENON CD Players and 2 DVD Players I modified. The laser power is just enough to successfully read high reflectivity CD ROM’s. As soon as you try to play low reflectivity disks – there’s a problem! You can increase the laser diode power. You can’t loose anything – but gain a year (or much more!) of service.
The proper way of doing this requires circuit diagram (or knowledge of the whereabouts of RF test point), and a CRO. The idea is to adjust the eye-patter RF signal amplitude. I use one particular disk for this purposes that has very low reflectivity (original disk bought in a music shop). I posted a few threads on how to do this adjustment approx. a year ago… Try the search engine and “eye-pattern” keyword. You’ll hear a “warning” bul$#@ suggestions from many, saying that it is dangerous to do this – but all you will be doing is adjusting the RF amplitude for a nominal pp value (+- margin/tolerance)! It is a common misbelief that laser pickups come pre-adjusted; this is wrong; they have to be fine tuned for each CD Plaer / DVD Player if you want to obtain optimal results with all your digital media.
Boky
Old 12th December 2006, 02:20 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Hi Boky,
I disagree with you 100%. Sony head and chip set. I have seen that many are not aligned perfectly from the factory. The other issue is the linear motor. Those rail need to be cleaned and relubed from time to time. Those machines are real winners when set up correctly. The laser power however is aligned properly at the factory. If you are messing with that, you are hacking the unit.
If you have a problem with those, then you also don't like machines like the Tascam CD-401 and many others. It all comes down to the tech that sets it up. I really like those machines.
Now, I do have an issue with the nature of the complaint. Any CD off spec will be a problem. CDR's are especially bad. In the early days we had many Sony (and other) units that would strip the feed gear due to these discs. DJ's mostly. We set these machines to read standard CD's. If you feed the machine some off standard - oh well. I see market pressure has required a change in servo design to an auto - set type. Your loss. The tech aligned units are better with good source material.
Anyway, you can't knock Denon or other manufacturer when an older machine is acting up. Just the same as you can't blame the car company when your older car won't run on kerosene. At least parts are available! You can blame the local agent if their prices are too high and their work is poor.
-Chris
Old 15th April 2007, 09:28 PM   #9
wsjoe is offline wsjoe  United States
Default denon cd player
Stoozo,
Do you still have the Denon 1520? I am interested in buying? How much to be shipped by sea/surface to USA? I was just there two weeks ago. BEAUTIFUL place.
keep those balls on the fairway...
Denon DCD 1520 not recognise some discHide this!Advertise here!
Denon DCD-2560 will not read disc... Cobra2 Digital Source 40 31st May 2011 09:02 PM
Denon DCD-1520 mods johngo Digital Source 10 14th August 2010 03:19 AM
Denon DCD 1520 20-bit or 18-bit? beauty_divine Digital Source 0 9th September 2007 06:41 AM
Converting CAL CL10 5 disc player to a single disc player stoolpigeon Digital Source 0 27th May 2007 01:25 PM
layout for tda 1520 Luckyme Chip Amps 0 8th March 2004 12:59 AM
Copyright ©1999-2017 diyAudio
