| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have an Audio Alchemy ACDII CD player that does not always identify cd's and on the display says ''no disc''.Any idea of what the problem might be?
#2 |
It could be a bad laser.
#3 |
Before discarding the laser -
Does it play the CD correctly once it is recognised? Does it play CDRs? If yes to both - the laser might still be Ok. I don't know much about this CD Player.....but if it is a bit old....like 10 years or so.......a little bit of servicing can work wonders. First - try cleaning the laser lense carefully. Second - inspect the mechanism and clamp that holds the CD in place. it might be worn or just need a lube. Third - replace all electrolytic caps in the power supply and mechanism. Oh - and don't forget to search for answers...... Some answers
Regards Fin |
#4 |
This is a most common problem concerned with CD drives. And this mostly occur due to allignment problem. The optical eye are alligned so precisely with a couple of strands. When they are improperly alligned out of some reason (bad cd reading) this takes place. There is no way in alligning them back properly, except replacing the lens system. If the laser diode is also damaged similar problem can arise. Check in the dark, it a red glow appears at the lens, while the tray is being inserted without a cd.Some times dust can also cause this problem. You can clean them using cleanable CDs.
#5 |
Fin,yes when it identifies the disc,it plays them ok.
#6 | |
Regards Fin |
| Audio Alchemy Dac Man | Alex Marx | Digital Source | 16 | 6th March 2010 10:05 AM |
| audio alchemy ps 3 | PAICE69 | Swap Meet | 0 | 24th March 2006 08:33 PM |
| EAD T-7000 CD/LD Player Audio Problem | dblack4 | Digital Source | 0 | 24th June 2005 04:24 AM |
| audio alchemy help | HIPCHECK | Digital Source | 2 | 1st June 2005 07:11 PM |
| problem with my audio alchemy DDE 3.0 | dexter | Digital Source | 0 | 23rd February 2004 03:39 AM |
| Page generated in 0.07988 seconds (73.69% PHP - 26.31% MySQL) with 10 queries |
