Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
dampening
dampening
Old 29th December 2002, 12:36 PM   #31
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default Learning The Hard Way......
"the definition of "experience" is 'having made so many mistakes that there are few left to make'.
I have made quite a few in my time, but at least I have tried a lot of things and have learned a quite a bit along the way!"
I have never made any myself, of course.
Eric, The All Knowing.
I believe not to believe in any fixed belief system.
Old 30th December 2002, 02:08 AM   #32
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default I STAND WITH BOB.
Hello ,
First of all Halojoy...pay some respect and get a life please?
Bob,
Your experiences on the topic are frighteningly close to mine....a lifetime dedication to the reproduction of music.
Whoever thinks CD is perfect,please think again...it needs at least as much attention to vibration control as a TT and has a lot more problems to boot.
Other than that there are are different other matters that need attention...
Ever wondered what it is you don't like about CDs?
Vibrations are just a minor problem,believe me...
Frank
Old 30th December 2002, 03:40 AM   #33
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
dampening
Default Re: I STAND WITH BOB.
Everytime i think about this, i think about the big Monty Python boot coming down to squah the music with spurei (sp) going everywhere (because it is unlikely that the Nyquist requirements are satisfied)...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th January 2003, 11:32 AM   #34
halojoy is offline halojoy  Sweden
On Hiatus
Default Anyone with a scientific Approach?
Originally posted by halojoy
Must be quite easy to test, if laser reading is changed
for better or worse.
Make a run without damping, record the digital signal.
Same with dampening, record the digital signal.
Use your PC to compare the signals.
No problem with todays digital in/out connections
soundcards and modern computer techniques.
The problem, why this is NOT done,
is probably that those people believing in benefits
of dampening are a bit afraid of the results.
They have a slight feeling that there is no difference!
/halo - does believe in fact - not hypothesis -
- and also believe in Jesus, The Man who Saves
I really thought someone would have some facts to present
based on research.
Or that someone in this thread was willing to do some tests
to prove the effect of mechanical dampening.
If there is an effect, then it should be possible to show
its existens.
By the answers, I can not find anything that contradict
my assumption:
The scientific minded people are quite busy
about the "Complex Emitter Follower".
Probably why they are not engaged in this thread.
Or they maybe find this subject somewhat uninteresting.
/halo
Old 5th January 2003, 11:50 AM   #35
Stryder is offline Stryder
You are either doing a little trolling or you have no idea about testing for microphonic output on an electronic circuit.
PS: You tap it whilst taking the trace.
CDP transport and electronics benefit from damping period.
Now go away and try it.
PS, if you are neither a troll or ignorant - read this and look at the generic specifications; then question in a really clever logical way why damping might help this complex arrangement. and what the roll of error correction and microphonics might play.
http://www.digitalcentury.com/encycl.../cdplayer.html
Gary Lawson SEP B.Eng Hons
Hubba Hubba
Old 5th January 2003, 12:04 PM   #36
Bobken is offline Bobken  United Kingdom
Halojoy,
It may seem arrogant to quote from an earlier post of mine, but I can do no better!
Originally posted by Bobken
"I would be very interested to hear further from you on this subject if and when you have some worthwhile feedback, based on practical experience, to add to this thread".
Regards, [/B]
Bob
Old 6th January 2003, 05:37 PM   #37
Sparhawk is offline Sparhawk
Sparhawk's Avatar
Default Re: Must be quite easy to test
Must be quite easy to test, if laser reading is changed for better or worse. Make a run without damping, record the digital signal. Same with dampening, record the digital signal.
Use your PC to compare the signals. No problem with todays digital in/out connections soundcards and modern computer techniques.
Such comparisons have been done in the past, not with damping mods in particular, but with other variables. More often than not, the data is found to be bit-identical. But this means nothing. You have to understand that musical data is not the same as computer data. With digital music, the timing of the bits is just as important as the value of the bits. Minute amount of jitter are audible. When you consider things in the time domain, digital components suddenly seem to have much in common with analogue.
Old 6th January 2003, 05:58 PM   #38
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
yes, the primary difference between analog and digital systems is the MANNER in which external inputs (vibration, power supply fluctuations, etc.) modulate the output and thus what type of distortion they produce. there is no question however that both systems are susceptible to such interference.
Old 6th January 2003, 07:13 PM   #39
frugal-phile(tm)
planet10's Avatar
dampening
Another scenerio where damping could be seen to benefit is: without damping we get more vibration on the disk making the laser mechanism work harder to track the disk. This causes more noise and load in the power-supply degrading the analog section of the player.
You will also note that all the high end players pay particular attention to damping. The Linn CD-12 for instance has a chassis milled out of a solid billet of aluminum into a shape that is intended to immunize it from external vibrations.
dave
Old 7th January 2003, 01:42 AM   #40
mrfeedback's Avatar
Default I'll Say It Again.......
Yup, thats what I said earlier on .
Additionally, digital power supply fluctuation causes modulation of the analogue waveform datastream slicer (jitter), modulation of the clock oscillator (jitter) and modulation of timings in the DSP chip.
Seperated power supplies for servo, digital and analogue audio stages pays big benefits.
Mechanical damping helps, but the electronics require attention also.
Eric.
dampeningHide this!Advertise here!
Dampening a must? squidbait Multi-Way 22 2nd April 2004 12:07 PM
dampening a cd player Joe04 Solid State 0 29th February 2004 09:42 PM
help on dampening please welly_59 Multi-Way 5 25th November 2003 02:35 PM
DIY Dampening Radik Multi-Way 17 18th November 2003 04:53 PM
Dampening in a car dsanders Multi-Way 4 29th October 2001 03:31 AM
