dampening - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 28th December 2002, 12:25 AM   #21
Bobken is offline Bobken  United Kingdom
Halojoy,
I am glad that I can at last find something in your post with which I concur.
I agree wholeheartedly that there must be an explanation for the beneficial effects of damping CD players which I have perceived during extensive listening trials.
The difference between us seems to be that simply because I don't happen to know what the true explanation is at this time, I will not ignore what is obvious to me and pretend that it doesn't exist.
Because I wish to have the best possible sounding audio system, I am prepared to invest the necessary time and will continue to carry out such trials, many of which, unfortunately, either don't seem to have any noticeable effect, or the result is no better.
The beneficial result I explained in response to the enquiry regarding CD players, just happens to be one of the 'success stories'.
I hoped my comments might inspire a few others to do the same, and see what they think, because damping CD players is perhaps not an intuitively obvious thing to try, but you have made it clear that you will not bother.
As an enthusiast, I cannot understand your reluctance, especially when I have shown you how to conduct a very simple, free, fully reversible, no-risk test, which would only take you a few minutes.
Sadly, your CD player will not sound as good as it could as a direct result of this, unless the manufacturer has already carried out this exercise effectively (but this would be the first time I have come accross such a situation, although several makers do make an attempt at eliminating some vibrations in CD players), but this is your choice.
Then again, I have not yet tried keeping my CDs in the fridge like you do, as I don't believe that there is any "electrical activity" in CDs to "reduce or eliminate" as you imply.
However, if, as you said, keeping CDs in the fridge does improve the sound of them (for whatever similarly unknown reason), I must try it out for myself, sometime, and if the sound improves, I will adopt that procedure in future, even though I cannot expain the technical reason for any change.
A Happy New Year to you.
Bob
Old 28th December 2002, 01:02 AM   #22
halojoy is offline halojoy  Sweden
On Hiatus
Arrow Hello Bobken
I am glad you are glad.
That was a joke, I do not keep my CDs in fridge!
But I can sometimes be, somewhat, ironical
in my remarks.
You haven't heard about my bad Casio calculator.
Which only gave an "E" when I tried to take Square root of -1.
I then asked, if I should buy me a more irrational calculator,
which could accept irrational numbers.
What is the fault in my Calculator?
But I have have heard guys that do this "tweak". With refridged CDs.
And also found out that having the CD on the metal kitchen sink
before playing them, will make them sound better.
Possible cause: Unloding static electricity from the plastic.
/halo - the joker in the diyAudio deck of cards
Old 28th December 2002, 01:48 AM   #23
Wombat is offline Wombat  Germany
Wombat's Avatar
What is obvious to me is that if the cd mechanism depends
on vibrations and the laser feels more comfortable - damping and
different materials will influence it all the time.
Acryl is very different behaving from all wood types in the
speakers i tried - and this is all vibration for sure.
So all makes sense.
Nobody should deny until he tested the existance of such things.
You sure need a good gear to start with.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 28th December 2002, 03:02 AM   #24
frugal-phile(tm)
planet10's Avatar
Default Re: What should be the logical explaination?
Originally posted by halojoy
The day I get the logical described to me (I am old fashion enough
to still trust in the law of Cause and effect)
That day I will start using dampening of digital machines.
To get better "1" and "0".
Just some points halo to point you in the direction of an explaination -- all circuits are microphonic to a certain extent, so damping the things that cause the microphony help, and there is a point in the process of getting the info from the disk into the CD electronics where we are really dealing with an analog RF situation (i pull this info from an interview with Julian Vereker -- someone who really impressed me when i met him). At this point it is not a 1 and 0 problem -- althou they are mixed in the syrup.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th December 2002, 01:55 PM   #25
Halojoy.
Great joke and a very worthwhile addition to this post.
I was completely taken in by you and thought you had become a Disciple of fellow countryman Peter Belt, who does espouse placing CDs in the freezer, but he says you need to write some special message on the bag you place the CDs in, for it to work.
Not yet having tried this, myself (and it is not at the top of my priority list!) I certainly will not make any scathing remarks about the procedure in a public place like this, in case it might inadvertantly wrongly influence anyone.
If I ever get around to trying it, I will let you know!
Wombat & planet10.
Just because I chose not to "rise to the bait" slung out by Halojoy and make any categoric statements which might indicate I think I know all about the reasons for the effects we notice here, it doesn't follow that I don't have any opinions!
I believe you are both correct in your comments, and I expect you were in turn as surprised as I was at the extent of the improvements which can be had with damping CDs.
Any means of giving the 'reading' mechanism an easier time would be almost bound to improve things, in my opinion.
No matter how good the inbuilt systems are for error correction or concealment, the interpolation circuitry cannot possibly make a better job of recreating (or sometimes blanking, where it cannot be successfully recreated) any missing information, which has been lost in the scanning process.
A lot of the time, it does a reasonably good job, although not a perfect one, but why encourage this circuit to work so hard anyway, if there are simple DIY ways of avoiding (or reducing) this?
I believe an analogy with a TT is reasonable in this case, and my TT doesn't care for me jumping up and down near it (and it doesn't have the 'benefit' of any correction circuits!) because that skips and misses bits of information in a big way, when I do that!
Actually, my guess is that in most cases the majority of improvement comes from the elimination of vibration caused to the electronic components, themselves.
You only need to remove a speaker Xover from the cabinet and listen to the marked changes and improvements this brings to the sound, to realise that electronic components simply don't like being shaken about!
In my tests on components, I have come across some capacitors which will make a sound (electrically- through the reproduction system, not from the body of the cap, itself) if you squeeze them, so they must be exibiting some kind of peizo-electrical behaviour, presumably.
Also, many caps will similarly make a noise through the system if you tap them with a screwdriver, or whatever, and I just don't want this kind of extraneous noise in my systems.
Many semi-conductors are definitely microphonic, too, but so far, I haven't noticed much of a problem with resistors performing badly in this way.
In my first CD damping trials, it was over a total period of some two years from start to finish, as I listened to every change individually, to ensure that nothing was being worsened.
This was following reading about someone else's experiences where he had said he had gone too far with damping and had accordingly taken some of the life of the sound away.
To be honest, I never noticed any such effect, and nowadays, I will go through say all of the semi-conductors at one time, and then in another 'session', perhaps try the caps, or whatever.
This speeds matters up a lot, but does provide some control over things, if anything ever seemed to be amiss. Whilst it hasn't yet happened to me as I said before, it would be lot easier to check back on the few components which have just been damped than to retrace all of one's steps back to square one!
Keep on damping, I say, and reap the sonic benefits!!!
Bob
Old 28th December 2002, 02:21 PM   #26
On Hiatus
Default Must be quite easy to test
Must be quite easy to test, if laser reading is changed
for better or worse.
Make a run without damping, record the digital signal.
Same with dampening, record the digital signal.
Use your PC to compare the signals.
No problem with todays digital in/out connections
soundcards and modern computer techniques.
The problem, why this is NOT done,
is probably that those people believing in benefits
of dampening are a bit afraid of the results.
They have a slight feeling that there is no difference!
Signal is to be taken DIRCETLY from the laser
before error correction.
This can surely be done!
That noone bothers to do RESEARCH of facts
I take as a silent admittance
that I am right in this matter!
As said earlier Turntables should be carefully
dampened and protected from Soundwave feedback in the listenning room.
And recording michrophones have to be that, too.
/halo - does believe in fact - not hypothesis -
- and also believe in Jesus, The Man who Saves
Old 28th December 2002, 05:57 PM   #27
Default Re: Must be quite easy to test
This is utter nonsence, Halojoy.
The only reason I (and, it seems a few others) don't carry out such a test as you suggest is that it would serve no useful purpose to me/us.
I don't need to prove anything to you, nor to anyone else for that matter, and I don't need any further specious 'technical' proof of what my ears tell me.
I don't know about your strange habits, but I happen to listen to the results (i.e. music) with my ears, and I am very pleased with what I hear with those same ears as a result of carrying out some CD player damping modifications.
If you wish to believe I am deluding myself, then so be it!
You are the loser for being too bigoted to even try a much more simple test which I have already suggested to you.
I still hope that the original enquirer (and any other open-minded reader) on this thread will carry on trying out such modifications for themselves, and not be discouraged by uninformed guesswork from someone who has no practical experience of what this thread is about.
If they do, they will soon realise who is talking sense, and who is not!
You may take my future silence on this topic, at least where any of your posts are concerned, any way you like.
However, the true reason will be that I don't intend to waste any more time on your comments because you haven't apparently made any efforts to try *anything* out for yourself, and yet you speak with apparent authority as if you are the fount of all knowledge in this matter!
Bob
Old 29th December 2002, 12:31 PM   #28
mrfeedback's Avatar
Default Digital Data Off The Disc Does Matter.......
Carl (halojoy), you are out of your depth on this cdp debate.
Bob, yes you will quite strongly affect and strongly effect the sound that you are getting out of your cdp by placements and type of damping materials that you are using.
In typical cd players, the currents drawn by the servo stages (spin motor servo, lens focus servo, and lens tracking servo) are high level, noisey, erratic and interdependent (intermodulating).
Due to power supply interdependencies (interactions) and grounds conductors reactances, a whole range of resonances and feedbacks, electrical and mechanical, inter react and cause a variety of distortions.
Because of the reactiveness of a typical cd player system, mechanically, electrically and electronically, the final output sound WILL change according to alterations made to the disc spin/laser reader subsystem.
There are a number of quick and dirty improvements that can be made to a typical cdp, and these include mechanical, electrical and electronic.
Eric.
I believe not to believe in any fixed belief system.
Old 29th December 2002, 01:29 PM   #29
Default Re: Digital Data Off The Disc Does Matter.......
Eric. [/B][/QUOTE]
Quite right mrfeedback, and the definition of "experience" is 'having made so many mistakes that there are few left to make'.
I have made quite a few in my time, but at least I have tried a lot of things and have learned a quite a bit along the way!
I wish I knew of someone well-known to quote at the foot of my posts who said something like " Theory has never prevented me from achieving things!"
Bob
Old 29th December 2002, 01:34 PM   #30
Pedja is offline Pedja  Serbia
Originally posted by Stryder
Has anyone here had success with dampening their CD players?
Yes, I think I did.
The things Iíve done (chronologically):
1. I put the player on the bike inner tire (and additional shelf). Generally speaking, the lower resonant frequency is better. Pumping tube, youíre also pumping the sound. I tried the glass, oak and MDF shelves. Glass had the best resolution, the MDF was best balanced, and oak was too murky for my taste. Tried also a few combinations of these. At this moment, I consider the MDF is the best compromise. (Base shelf is made of glass)
2. The player originally had a double aluminum bottom plate. I added one more bottom plate of 19mm MDF. The result: more analog sound.
3. Changed original feet with four solid aluminum, adjustable, spiked feet. This results in more pleasing sound and better resolution. I also tried a few arrangements with three feet, but did not like what I heard.
4. I applied 4mm rubber at all free inner sides of the unit (not at the bottom, because I soldered some parts underneath the PCB, no place to did that). Little strange effect, the sound became cleaner, but less transparent at the same time. It may be better if I applied many small patches at the inner side of the hood (I put one big).
So, I recommend the first three mods. As for fourth, Iím still not sure if it is good or bad. Iím planning to put another bracing on it.
Pedja
Dampening a must? squidbait Multi-Way 22 2nd April 2004 01:07 PM
dampening a cd player Joe04 Solid State 0 29th February 2004 10:42 PM
help on dampening please welly_59 Multi-Way 5 25th November 2003 03:35 PM
DIY Dampening Radik Multi-Way 17 18th November 2003 05:53 PM
Dampening in a car dsanders Multi-Way 4 29th October 2001 04:31 AM
Copyright ©1999-2017 diyAudio
