| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hey folk, did you have a plan to use CS8420 & CS8414 paralel, I need a simple configuration, want to use upsampling and true 24/96 feeding to my DAC using DF1704 and PCM 1704
#2 |
yap.. elektor electronics have published an upsampling unit based on crystal cs8420, providing both i2s and s/pdif outputs you can find the pcbs in www.elektor.co.uk under the numbering 010014-1
#3 |
Thanks costiss but if you be pleased I'm to plan use CS8420 and CS8414 simultanously in one PCB, perhaps w/ some logic controller and sensing wich input being use, other way want use input 16/44 data upsampled and true 24/96, btw the link is dead, thx for companion and attn
#4 |
http://www.elektor-electronics.co.uk/ sorry..wrong link
this upsampling unit when loaded with 96kHz S/PDIF signal acts as a bypass BTW imposes no change other than the S/PDIF->I2S conversion - no reason to use the cs8412.. |
#5 |
the pcb is tofind in issue no 298 april 2001
#6 |
Thanks costiss, how did you know when fed by 96kHz this CS8420 by passes the signal, I'll check the data sheet also, btw from elektor can download the pcb, is that good I'm not really looking the design, once again thx
#7 |
elector published some performance tests along with the article....
#8 |
costiss
what are the details for the inductors used? Any chance of getting the complete article? Thanks very much for the info Yv |
#9 |
Yeah Costiss, if you dont mind can you put that article in this forum or at least by email
"Single Ended Single Driver Single Minded" btw r u also a WRC fans? |
#10 |
unfortunately the article is in greek :-( - i dont have the english issue - should be may 2001
| Can i paralel the 2 opamps in 5532? | jondoe | Chip Amps | 6 | 17th December 2004 04:53 AM |
| paralel MOS-FETīs HELP | viki | Solid State | 4 | 17th September 2004 01:59 PM |
| TDA 7293s paralel ,voltage... | B.I.G | Chip Amps | 0 | 18th March 2004 08:37 PM |
| Trade: 1pcs CS8420 for 1pcs CS8414 | hifi | Swap Meet | 1 | 11th December 2003 04:23 PM |
| Paralel resistor | jan | Multi-Way | 9 | 5th September 2003 05:11 AM |
| Page generated in 0.11401 seconds (80.48% PHP - 19.52% MySQL) with 11 queries |
