| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello I am interested in interfacing an AD1865 to a PMC2706 to make a USB DAC. I've done a bit of searching on this and seen a few different solutions, but have never seen a finished project with it. It seems most people resort to the TDA1543.
I was intending on using the I2S out from the PCM2706 and sending this to an AD1896 ASRC, then setting the output for 18bit L justified. Also what about the clock for the AD1896...can I just use an additional crystal? Any advice on this will be helpful as I am a digital noob! Thanks G.
If you take something apart and put it back together again enough times, eventually you will have two of them. |
#2 |
There is no reason why this won't work. The AD1896 needs a master clock and if you use the output serial port in master mode, the quality of this clock becomes critical.
| Pcm2706-tda1543 Usb Nos Dac - Aw-d3 | pftrvlr | Swap Meet | 0 | 10th November 2008 02:35 AM |
| PCM2706 not working | Eddy Dean | Digital Source | 13 | 23rd August 2008 09:55 PM |
| Possible PCM2706 implementation | jaycee | Digital Source | 9 | 5th November 2006 11:14 PM |
| AW-D3 (PCM2706) problem | pipp0r | Digital Source | 7 | 30th April 2006 09:37 PM |
| 3.3V PSU to drive PCM2706 USB DAC | Nordic | Digital Source | 21 | 11th February 2006 03:09 PM |
| Page generated in 0.07510 seconds (71.90% PHP - 28.10% MySQL) with 10 queries |
