Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
KSS 240A pick up...CD player parts
Old 17th November 2006, 08:20 PM   #11
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Default Flat cable
Yes, might, since there's a crack as well.
-=Hugo=-
Old 17th November 2006, 08:46 PM   #12
anatech is offline anatech  Canada
anatech's Avatar
Hi Hugo,
Looks like a blob of grease, but it could be a dented cable also. Sharp eye!
It's been quite a while since I've seen a bad one, but why not. Especially since they are even older now.
-Chris
Old 17th November 2006, 08:49 PM   #13
Netlist's Avatar
It would be nice to get an update from qguy
/Hugo
Old 17th November 2006, 09:00 PM   #14
anatech's Avatar
Hi Hugo,
Yes, true. But it's nice to chat with you also!
-Chris
Old 17th November 2006, 09:07 PM   #15
Netlist's Avatar
I'm flat-tered.
/Hugo
Old 18th November 2006, 12:26 AM   #16
chaoticjelly is offline chaoticjelly  United Kingdom
Ok thanks for the advice guys.
When I compared the new pickup to the old pickup I noticed that 2 out of the 3 white pots at the back were differently arranged.
I read on another thread here that these are factory set and should not be altered.. so I did not alter them.
However I dont have access to an oscilloscope, ive been after one for a number of months but to no avail..
Would it work if I adjust these two white pots to look the same as the old pickup?
Will the squeal eventually destroy the laser with use, or is it just annoying but harmless?
Many thanks for your advice to this pickup newb, your very kind
Old 18th November 2006, 02:52 PM   #17
anatech's Avatar
Hi chaoticjelly,
Those controls are for laser power and offsets. I really don't want you to touch them, "no good will come of this" as my wife says. The gain controls should be on the PCB. The gains are switchable electronically and are higher in search mode. The controls will change the play mode gain. You need an oscilloscope do do anything constructive.
Less damage will result if you leave them alone. But this is one reason a good technician costs more, but is cheaper to use in the long run, sometimes in the short run too!
-Chris
KSS 240A pick up...CD player partsHide this!Advertise here!
Jeil JPA 240A circuit JDeV Solid State 3 6th April 2016 05:59 PM
Optical Pick Up for CD Player Wholesaler or Manufacturer? tiefbassuebertr Digital Source 15 27th April 2013 11:28 PM
KSS-240A based transport for DIY-Player Salar Digital Source 0 1st March 2009 11:35 PM
F.S: Philips / Marantz CD-player parts Cobra2 Swap Meet 31 26th May 2008 08:00 PM
Replace KSS-240A on a Sony CD player MP Parts 1 15th July 2004 01:17 PM
