| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
If i want to use an existing dsp board, (with accepts an I2S input) but add multiple I2S inputs paths, what is the best way to select between them? Here is the basic flow:
(Input 1) 3 toslink, 3 coax -> cs8416(mux in software mode) -> ad1896 -> I2S on dsp board (Input 2) 3 analaog -> relay selector -> buffer -> pcm1804 or ak5394 -> I2S on dsp board If I want to feed the same I2S header on the board, what is the best way of doing so. I am coding a controler for input selection via rotary, so software control is definately an option. Thanks, Hans |
#2 | |
I do it as well and it works perfect
www.dddac.de Happy listening and building |
#3 |
You could use the 74xx257 or 74xx157 for switching the 2 i2s signals.
they are "QUADRUPLE 2-LINE TO 1-LINE DATA SELECTORS/MULTIPLEXERS" regards |
| Switching current source for Class A? | QED047 | Solid State | 101 | 27th November 2010 03:49 AM |
| Need case source for switching supply | phrarod | Chip Amps | 0 | 21st January 2008 10:09 PM |
| Input source switching | Stuey | Chip Amps | 6 | 2nd October 2006 09:46 AM |
| switching regulator as a current source | SS | Parts | 13 | 10th February 2004 02:58 PM |
| BOSOZ source switching with SE relays | Gabrielshorn | Pass Labs | 2 | 5th February 2004 09:07 AM |
| Page generated in 0.07946 seconds (71.39% PHP - 28.61% MySQL) with 10 queries |
