| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Are there any R2R ladder dac chips in current production (other than pcm54/55).
I am interested in building a R2R dac, maybe even from the grass root level i.e. use actual high precision (0.1%), high stability, low current noise ( 1µv/V) resistors to build the ladder. Are there any standalone R2R ladder chips readily available ? Doesn't have to be a "DAC" chip. I/V conversion and output buffering can be external, or rather I'd prefer that. Thoughts anyone ? |
#2 |
You don't like PCM1704? Despite being "not recommended for new designs" they are still produced.
#3 |
oftmof pcm56 or pcm63 or tda1541...
But I'd just like to build it this way. I'd just like to be able to write to a multi-bit latch that is in turn tied straight to a "DAC" (ladder). How I write to the latch, and how often, is what I'd like to see open for trying out a few possibilities. If not anything else, just for the fun of it... |
#4 |
For 16 bit you need a little better than 0,1%.
And tight Ron-matched switches. Accuphase used ICL8019 current switches in their early DACs. I tried 1 PCM54 / bit. Works so far. |
#5 | |
I have seen a few measurements you've done on various dacs but I have never seen one for the PCM54. Did you ever do any ? |
#6 | |
I have 16 pieces of PCM54 and one or two are quiet good with MSB adjust. PCM56 I have about 90 and nearly 50% are very good with MSB adjust, the rest ranges from good to horrible. PCM56 is much better than all the rest. My favorite in nonos with passive I/V. PCM53 has no MSB adjust, I have about twenty, one is good. PCM58, PCM63, PCM64, AD1862, PCM1702 I have a few of each but non is good. TDA1541/1541A was never good, except one out of 10 crowns. And I have a pair out of four ceramic/gold chips that is good, maybe I was lucky |
#8 |
AD669 83dB SNR ?
#9 |
| Which chips are out there? | Mayday | Chip Amps | 9 | 23rd September 2007 12:42 PM |
| How good is PCM54? | mudihan | Digital Source | 5 | 18th September 2007 09:09 AM |
| Re : BL type & GR type of transistor for Aleph-Ono | Arion | Pass Labs | 4 | 29th January 2007 06:15 PM |
| IC resistor ladders...has anyone used them? | Spasticteapot | Parts | 0 | 6th November 2006 02:41 AM |
| Chips for Chumps aka "Intelligent Chips" | jackinnj | Solid State | 0 | 15th April 2005 12:37 AM |
| Page generated in 0.09046 seconds (78.03% PHP - 21.97% MySQL) with 10 queries |
