diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   Is it true? (http://www.diyaudio.com/forums/digital-source/89312-true.html)
rick57 30th October 2006 11:41 AM
Is it true?
That in PC audio, jitter is not really an issue?
philpoole 30th October 2006 10:22 PM
Hi Rick,
If you're using an external DAC with your PC, be it on a USB cable or a soundcard, its a DAC. In this case, jitter will of course be an issue.
Within what context are you referring to (i.e. am I missing something?).
Phil
rick57 31st October 2006 01:42 AM
Hi Phil,
I read www.positive-feedback.com/Issue22/nugent.htm
where an EE suggested/ claimed in PC audio, jitter is not really an issue, though without any detail etc
I'm a sceptic . . but
I’m going over to PC audio for a audiophile system, and a family system; one internal soundcard, the latter external to a 2nd hand notebook. (Both M-Audio, cheap off eBay)
While planning these two PC audio systems, I was hoping for some similar conclusions/ clarification/ measurements
Rick
metalman 31st October 2006 05:37 AM
Somewhere on the TI website there is an article on the development of the SpAct architecture that they had to develop to create the compatability between USB (an asynchronous signal) and digital audio formats (which are synchronbous). It details in more detail than I could ask for the issues surrounding jitter and USB audio transfer. I'd recommend looking it up.
The short answer to your question from that article is that the USB transfer eliminates all jitter related to the normal sources in a CD player, but does not eliminate jitter completely. There is still jitter from the innacuracies of the clock source feeding the USB converter chip, the accuracy of the PLL within the USB chip, and possibly even from noise in the power supply feeding the USB chip.
Cheers, Terry
rick57 31st October 2006 08:50 AM
Thanks, Terry ;)
I'll check it out
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
