Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
marantz cd63 spin anti clockwise???
Old 30th October 2006, 11:11 AM   #1
robertc is offline robertc  Malaysia
Default marantz cd63 spin anti clockwise???
recently i changed my cd63 with a new cd12.1 len. after a few days, when i play it show error No Disc. when i try again with cover off, i noticed that the cd spin anti clockwise???? please help.
Old 30th October 2006, 03:29 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
Default Re: marantz cd63 spin anti clockwise???
Have you gone through the self-test routine ?
Andy
Old 30th October 2006, 05:59 PM   #3
avr300 is offline avr300  Denmark
avr300's Avatar
Check for damaged ribbon cable. Check for bad connection to main board. And as Andy said, run a self diagnostic.
Old 1st November 2006, 10:37 AM   #4
yes i did, the error is err 02(focus error)
the voltage to the motor is neg.5v and why not pos.5v??
can i change the motor wire the other way round?
Old 1st November 2006, 02:51 PM   #5
poynton's Avatar
NO, do NOT change the motor wire over - it is correct. The fault lies elsewhere !!
Did you run through the complete selftest routine ?
What were the results ? step by step ?
Why did you change the cdm in the first place ?
It could also be that one of the cables has come slightly apart or that the circuit track has been damaged in replacing the cdm.
Andy
Old 1st November 2006, 11:17 PM   #6
this is my 3rd time to change the cdm because of not focusing.
at first it run normal ,if i damaged something when i replacing the cdm i don't thing it can play for a few days
the problem is why the voltage from TCA0372 to the motor now with negetive 5volt and not positive?
Old 2nd November 2006, 08:56 AM   #7
poynton's Avatar
I suspect that somewhere there is a dry / bad joint on the pcb which is going good occaisionally. It may be on the main pcb or on the small cdm board.
You will need to remove the main board and carefully check/resolder every joint looking for obvious dry joints.
NOTE :- the CD63 board is prone to breaks in the pcb tracks next to solder joints - be carefull !!
If possible, get hold of another CD63 and check by changing the cdm.
Also, did you carry out the full selftest ??
Andy
Old 2nd November 2006, 02:08 PM   #8
the cd not spin when i press play. only spin when i try in test mode but spin anti clockwise.
Old 2nd November 2006, 02:56 PM   #9
poynton's Avatar
Then you possibly have a problem on the HF board. Check by changing for a known good board or resolder.
The problem may also be a dry joint on the main board.
The disk does not spin when play is pressed because it has not found focus.
The backwards spin is a symptom of the fault not the cause.
Andy
Old 6th November 2006, 11:55 PM   #10
Extreme_Boky is offline Extreme_Boky
Check TCA0372 pins 1, 7 and 8. When in idle, pin 1 = 0, pin 7 = 2.5V and pin 8 = 2.5V. This IC opens and closes the tray AND controls the spindle motor. Spindle motor control = pins 1, 7 and 8.
Carefully check ribbon cable connections (one from the laser assembly as well!).
If things look grim - send it for Service...
Good luck,
Boky
marantz cd63 spin anti clockwise???Hide this!Advertise here!
WTB Marantz CD63/67 Mindcrime Swap Meet 6 30th January 2009 12:35 PM
Marantz CD63 palucca Digital Source 3 27th September 2008 11:10 PM
Marantz CD46 won't spin ssjenkins Digital Source 1 13th May 2008 03:49 PM
Marantz cd63: PWM to DSD ? ash_dac Digital Source 0 24th February 2006 09:59 PM
Marantz CD63 KI op amp circuit Fidelity Audio Digital Source 2 22nd December 2005 02:15 PM
