Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th October 2006, 11:58 PM   #1
Will is offline Will  Malaysia
Default NEC 601 multispin - i/o BUS to IDE ??
Following the previous thread of tapping the CXD2510 i2s signals to a TDA1545A, I have successfully done it with the multispin cdrom.
I also have a cdrom controller with uses an IDE interface to a normal cdrom, but noticed that the NEC uses i/o bus interface with its connector much broader than an IDE. Is there a way/ or is there an adaptor that I can use ? This done so that I can remotely control the NEC using the cdrom controller that comes with a remote handset.
Old 30th October 2006, 04:40 AM   #2
dangus is offline dangus  Canada
If it's MORE pins than IDE, (like 50 of them), it could be SCSI. I'm pretty sure there's no such thing as a SCSI to IDE converter. And if there was it'd cost a lot more than an IDE CDROM is worth these days.
Old 30th October 2006, 05:08 AM   #3
I though SCSI connectors are much more compact than IDE; is it possible that older generation SCSI connectors are shaped like the IDE but just wider ?
FS NEC Multispin CDR-602 JohanH Swap Meet 2 28th January 2006 05:35 AM
FS: NEC MultiSpin 6X CDR-502/602 oPossum Swap Meet 1 29th October 2005 01:06 PM
WTB: NEC Multispin 6Xe unit bamadawg Swap Meet 7 12th May 2005 08:46 AM
NEC Multispin 4x4 Model CDR-C251 for sale chipco3434 Swap Meet 0 20th April 2004 03:08 PM
Page generated in 0.07480 seconds (68.67% PHP - 31.33% MySQL) with 10 queries
