Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th October 2006, 05:01 AM   #1
Sunsun22's Avatar
Default What is the purpose of TL431 in this circuit?
This circuit is from a power supply to CS-8412 +5V rail. The DC is 7V from a 317 regulated source. Since this is already regulated by 317 to 7V, we can config 317 to produce 5V. Why does it need to add another regulation stage by TL431? If TL431 is better than 317, then we should feed the DC after rectification and cap to TL431 to produce +5V, then why is it necessary to go through 317?
Old 27th October 2006, 08:52 AM   #2
Archwn is offline Archwn  United Kingdom
would be a double regulated config. to increase the performance of the power supply or something. You might get better sound IMHO
Old 28th October 2006, 02:39 AM   #3
dangus is offline dangus  Canada
Search for stuff about "shunt regulation". I think that's what is going on here.
Old 28th October 2006, 08:11 AM   #4
Sunsun22's Avatar
Yes TL431 is a shunt regulator but is a regulated voltage (from 317 in this circuit) a pre-requisite to perform shunt regulation?
Old 28th October 2006, 08:48 AM   #5
clem_o is offline clem_o  Philippines
Shouldn't be a requirement, but a quieter voltage feeding the TL431 (or any regulator for that matter) should serve to drop the supply noise on that output line further.
Old 28th October 2006, 12:41 PM   #6
The 431 acting as a shunt should be fed with a current, I suspect the 317 is configured as a current source. Show us the full schematic and it will become clear.
best
Guido Tent
www.Tentlabs.com
Old 28th October 2006, 01:05 PM   #7
sivan_and's Avatar
Send a message via Yahoo to sivan_and
TL431 is a band gap referenced shunt requlator..If fed from a constant current source the accuracy will increase..
SivanandBalan
Old 28th October 2006, 01:14 PM   #8
Why ?
cheers
Guido Tent
www.Tentlabs.com
Old 29th October 2006, 01:02 PM   #9
Sunsun22's Avatar
I have difficulties to reduce the entire circuit. But with a little help from my friend, here is the complete circuit.
Old 29th October 2006, 01:12 PM   #10
Indeed, the 317's are configured as current sources. Unfortunately the designers short the current sources with lytics - too bad.
best,
Guido
Guido Tent
www.Tentlabs.com
Need help understanding TL431 Archwn Power Supplies 33 21st May 2008 08:57 AM
What's really going on in that TL431 jackinnj Power Supplies 3 6th May 2007 01:22 AM
The purpose of R0 in Aleph 30 circuit Peter Daniel Pass Labs 8 28th March 2005 09:47 PM
Purpose of Parallel Capacitor with AD811 I/V circuit? fastcat95 Digital Source 3 9th February 2005 05:09 PM
Tl431 sparkle Digital Source 11 22nd February 2004 09:10 PM
Page generated in 0.09006 seconds (81.24% PHP - 18.76% MySQL) with 11 queries
