| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Got a Sharp DVD player model DV-740 that had gone bad. Switched on the wall plug, no standby light, unable to power up the unit. Suspect some components on the power supply board are dead. Any service manual, schematics & advice?
Thanks! |
#2 |
My guess it's a smps, they tend to be quite complicated devices.
Repairing it might only be possible using a scope...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#3 | |
But Assyst,you need to open up the casing to check it. |
#4 |
I have checked & replaced some of the components but still it doesn't power up (no standby light on). I went to some of the local electronics shops but they can't identify some of the components rating. Perhaps a service manual & schematics might help.
#5 |
Don't have the schematic nor service manual, but from the picture it appears that there isn't any switcher IC?? Either that or it's under the board... you'll be very lucky if it's a 'discrete' switcher - good probability of getting it fixed.
Cheers |
#6 |
Hi, Thanks for the reply. The switcher IC should be the one near the big capacitor. I have changed that. I think the big capacitor maybe the problem. Now i recalled seeing some electrolyte coming out of the base.
#7 |
The big capacitor would be your mains filter. Mains power comes in, goes through some line chokes (Toko) and line capacitors (the blue ones), then into a rectifier (the four diodes near the two Toko). That should be a 350 or 400V electrolytic, maybe 220uF... Is there rectified DC on it? It should be about equal to (your line voltage * 1.414).
Cheers |
#8 |
You are lucky,dude
Your part number should be the popular KA5x380R.I attached the link for your reference. www.fairchildsemi.com/an/AN/AN-4141.pdf BTW,is your DVD player based on a DVDROM and an ESS chipset??? |
#9 |
i have one of these dvd players also faulty.. but its different, mine the standby light comes on and all the voltages from power supply look ok.. i just cant get the thing to come out of standby :S
Owen |
#10 |
Maybe you got problem with the decoder board or the DVDROM.
| Help a noob with sharp cd player | scribbles | Digital Source | 2 | 10th September 2008 04:05 AM |
| Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. | Spasticteapot | Swap Meet | 0 | 7th October 2006 08:12 PM |
| How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? | jelou | Digital Source | 4 | 29th April 2004 03:48 AM |
| Stand Alone CD Player vs. DVD Combo-Player | Tom D | Digital Source | 0 | 2nd January 2003 04:08 PM |
| Page generated in 0.11029 seconds (80.93% PHP - 19.07% MySQL) with 11 queries |
