| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
If you are using a lossless format, specifically FLAC (via EAC) is there anything lost in sound quality, in using the highest compression?
As either way it's lossless, the apparent answer is no. But could well be there's something I'm not aware of. I believe that some people do not using the highest compression - why is that? Thanks |
#2 |
The "highest" compression is something like 1% difference in size from "low" compression. There's really no point most of the time.
#3 | ||
http://www.ecpaudio.com |
#4 | |
#5 |
(FWIW, I’m a pop/rocker too)
For only 5% difference, I’d probably save the CPU a little heat . . Anyone getting more than 5% saving? |
| Compression ratio and diaphragm size in compression drivers | inkasound | Multi-Way | 50 | 8th January 2009 03:38 PM |
| Is it true that the higher the BL of a subwoofer, the higher its lowest playable... | 454Casull | Subwoofers | 16 | 19th March 2004 04:28 PM |
| Flying higher and higher with the Doede Dac | Lucas_G | Digital Source | 139 | 27th February 2004 06:40 AM |
| Super-power amps - higher current better than higher voltage | Circlotron | Solid State | 34 | 28th June 2002 04:01 AM |
| Page generated in 0.08106 seconds (75.29% PHP - 24.71% MySQL) with 10 queries |
