| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi, my arcam delta 250 transport is making some mechanical noise when playing - a kind of high frequency whistling noise. Its not loud but it can be heard at my typical listening levels. I think it has allways made some noise (bought second hand) - maybe its now worse or i am less tolerant
as it's now closer to my ear Seems to work OK anyway but the noise is annoying ...I did some research a while back and discovered it is fitted with the phillips CDM9-pro mechanics. Is this noise a sign of impending failure in the transport thanks in advance, dave |
#2 |
Could this be the tracking servo working overtime ?
#3 |
Does the whistle ever 'change' in pitch or stop? Do you ever hear it get modulated (i.e. chatter), for example when doing a fast-forward?
Cheers |
#4 | |
Magneto the Gravity Man
The early CDM-12 mechanism suffered from a similar problem. A mod kit was available and later versions were slightly different. The mod was to the small metal disk in the centre of the clamping mechanism. A 5p coin glued to the disk solves this problem. It may help. Worth a try ? Andy |
| Arcam Delta 290 | lduarte1973 | Solid State | 2 | 28th February 2009 09:06 AM |
| Arcam D250 CDM9 TOC Issue? | jonclancy | Digital Source | 6 | 10th June 2008 07:14 AM |
| Arcam Delta 70/70.2 | FibCouple | Digital Source | 2 | 12th January 2008 11:42 PM |
| Delta 290 Arcam | mike salway | Solid State | 0 | 17th September 2005 03:03 PM |
| Arcam Delta 70.2 | Rotellian | Digital Source | 2 | 16th January 2004 10:33 PM |
| Page generated in 0.08107 seconds (75.82% PHP - 24.18% MySQL) with 10 queries |
