Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
LC CLOCK for 33.8688MHz or above
Old 21st December 2002, 04:07 AM   #1
nFORCE is offline nFORCE  Japan
Send a message via ICQ to nFORCE
Default LC CLOCK for 33.8688MHz or above
Hi all,
Who know how to make it?
Please give me some hints.
Thanks alot
nFORCE
Old 21st December 2002, 05:28 PM   #2
alfsch is offline alfsch  Germany
at these frequ you need overtone-mode osz, the most simple to start and (for me) as a reference is a gate-osz; later you can build another, like a colpitts type and hear, wether you can improve quality...
here is my circuit: works at 33,x MHz
alf
Old 22nd December 2002, 10:43 AM   #3
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb LCAudio Clock
Hi nForce,
What's in the LCaudio clock can be found here:
http://www.diyaudio.com/forums/showt...antz+AND+clock
(bottem of page).
Alfsch, here you will also find my opinion about CMOS Pierce type oscillators.
The Section 5 PDF file is now at
http://www.analog.com/Analog_Root/st...g/Section5.pdf
AD keeps changing its website!
Old 22nd December 2002, 12:41 PM   #4
Wombat is offline Wombat  Germany
Wombat's Avatar
@nForce
When you build the clock of alfsch - be sure to use this 74VHC
type of Hex-Inverter.
I changed my 74HCU04 to this 74VHC04 and sound improves quite
a bit!
I have a 49,15MHz clock in my Sony DAC.
If time permits - stuff some parsley in your ears and listen how it grows!
Old 23rd December 2002, 12:20 AM   #5
Default Re: LCAudio Clock
Dear Sir,
At your old post, I found that
"If your need a higher frequency for example 33 MHz for DVD you will need a overtone circuit, that I also can provide"
Could you mind give me some hints of 33.8688 and 45.1584MHz?
Merry X'mas
nFORCE
Old 23rd December 2002, 06:19 AM   #6
Banned
Lightbulb Re: Re: LCAudio Clock
Originally posted by nFORCE
Dear Sir,
Merry X'mas
nFORCE
Hi nFORCE,
I am sorry that information is obsolete.
A <B>fundamental</B> mode 33.8688 MHz and 45.1584 MHz crystal will work in the regular KWAK-CLOCK.
See also:
http://www.diyaudio.com/forums/showt...ght=optimising
The post: "Low Jitter Crystal"
Merry Christmas too
Old 23rd December 2002, 06:25 AM   #7
HpW is offline HpW
>> VHC04
Keep in mind that the xxxxU04 must be used for oscillattors !
See also related VHCU04 on Fairchild :
Since the internal circuit is composed of a single stage inverter, it can be used in analog applications such as crystal oscillators. An input protection circuit ensures that 0V to 7V can be applied to the input pins without regard to the supply voltage. This device can be used to interface 5V to 3V systems and two supply systems such as battery backup. This circuit prevents device destruction due to mismatched supply and input voltages.
and see the VHC pdf file with the gain curve of VHCU04 and the alike level trigger threshold behavior for VHC04!
www.fairchildsemi.com/pf/74/74VHC04.html
www.fairchildsemi.com/pf/74/74VHCU04.html
VHC general : http://www.fairchildsemi.com/ms/MS/MS-521.pdf
Cheers
Hp. Widmer
Download FFT Analyzer & Generator at www.hpw-works.com
Old 23rd December 2002, 07:45 AM   #8
Wombat's Avatar
Well,
all i can say - when using the 74VHC without "U" i can here the more rlaxed and cleaner
sound (most mids) against the 74HCU without "V". Don´t know how the 74VHCU is sounding.
The fairchild pdf says about the 74VHC without "U"
"The internal circuit is composed of 3 stages including buffer output, which provide high
noise immunity and stable output...."
Maybe this counts also!?
Old 23rd December 2002, 09:32 AM   #9
HpW is offline HpW
Did you ground the crystal box ? Use also smd caps for the oscillator and block the IC with additional 0.1uF smd cap's!
While overtone is not a very easy task in case not haveing related measurement instruments to measure the phase noise!
Cheers
Hp. Widmer
Old 23rd December 2002, 10:25 AM   #10
Wombat's Avatar
It is an existing clock in a Sony SDP90 sound processor DAC.
All i have done is changing the Hex-Inverter.
I can post the shematic later.
LC CLOCK for 33.8688MHz or aboveHide this!Advertise here!
My CD Clock - the "Kwok Clock" kwokm Digital Source 13 10th September 2006 12:34 PM
CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation stolbovoy Digital Source 7 3rd December 2004 07:18 PM
Audiocom clock vs. LC Audio clock KevinLee Digital Source 22 26th July 2004 01:29 PM
Kwak clock versus Tent clock rbroer Digital Source 22 21st September 2003 01:20 PM
33.8688Mhz fundamental mode crystal Freddie Parts 0 1st April 2002 10:38 AM
Copyright ©1999-2017 diyAudio
