| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
digital distribution around the room/house avoids much of the interference and degradation inherent in long analogue cables (if the source is already digital). Is there a method of taking the 6channels from a 5.1 source and combining the signals into pairs in the digital domain? rears as a pair, fronts as a pair and finally centre and sub as a pair. Then each of the two channel pairs could be decoded at the receiver end (by conventional 2channel SPdif decoders). What's available? Or does the data protection system prevent this?
regards Andrew T. |
#2 |
Demultiplexing a 5.1 datastream will not decode it.
#3 |
I guess that's why one would need some hardware. Convert the 5.1 to 6 channels of conventional digital stream and then combine two channels together to form an SPdif digital data stream. Then distribute. And finally decode the two channel SPdif data stream into the two analogue outputs. Or plug straight into SPdif on the back of the speaker and let it do the two channel decoding. Mine (Tannoy Reveal6D) have a left/right/mono switch just waiting for an SPdif input.
regards Andrew T. |
#4 | |
AKA The AC3/DTS decoder. |
#5 | |
does Quote:
All the decoders I have seem on domestic equipment send out either a 5.1 digital data stream OR 6 channels of analogue and sometimes both. But I have never seen three data streams of 2channel information or 6 data streams of single channel information.
regards Andrew T. |
#6 |
They exist but are not that common and are often very expensive. The Theta Casa Nova will set you back around £4000. The other option is to modify a player that allows access to the decoded digital data in 3x2ch form. 6 single digital channels would be virtually useless.
#7 |
Well, most of the times the 5.1 data comes as AC3 or DTS and that can be sent over standard SPDIF without any problems. Most of the available DVD players and receivers have this feature, and most pc soundcards cand send this info unaltered for a receiver.
I don't see why is would necessary to decode to analog and then encode again (further losing quality), when the means to transmit the information in the digital domain are available already.
Deep down inside. |
#8 | |
#10 |
I don't see the point. Why not just transmit the original 5.1 bitstream to the remote receivers?
| Six channel Surround Amp | Rainwulf | Chip Amps | 2 | 7th March 2009 11:17 AM |
| cdrom spdif quality / sound card spdif | metebalci | Digital Source | 0 | 2nd September 2006 07:16 PM |
| SONIX SN11116 - SPDIF 6 channel recording? | windyweather | Digital Source | 0 | 18th February 2006 07:55 PM |
| Group Buy for 5.1 Channel PCB's for Computer Surround Sound | DSchmidt | Group Buys | 2 | 1st January 2006 06:28 PM |
| How to set a 5.1 channel surround system | sundareg | Multi-Way | 7 | 13th August 2003 02:48 PM |
| Page generated in 0.10036 seconds (77.26% PHP - 22.74% MySQL) with 10 queries |
