Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Is it possible to set non os mode in Philips CD130 with M50423FP signal processor?
Old 11th October 2006, 03:11 PM   #1
Angelm is offline Angelm  Bulgaria
Default Is it possible to set non os mode in Philips CD130 with M50423FP signal processor?
I found Philips CD130 (dac 1543) in mint condition, so I want to upgrade to non os mode.
Unfortunately, it is with Mitsubishi M50423FP signal processor.
In the PDF I found on page 17/18 described available mode.
Now it is set mode 5.
Do you think, it is possible to set mode 7 or 9.
Will this have effect on digital out - pin 4 DOTX
Sorry bother you with this strange processor.
http://www.datasheet4u.com/download.php?id=551540
Old 11th October 2006, 07:34 PM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
I read the datasheet of m50423fp.
For Fs or nos tda1543 MSB 1st.
Mode 7 is interpolation - For use with external digital filter.
That leaves mode 2 or 9. Fs bypass filter. Timing different.
Pin 4 DOTX = spdif.
You can hardwire to get what you want.Just follow the table 1.
1=Vcc or 0=Gnd. DASEL 1 - 4
Old 13th October 2006, 04:49 PM   #3
Thank you singa,
I will try mode 9.
Anyone else has Close Encounters of the Third Kind
with this Mitsibushi processor ?
Old 8th January 2007, 08:14 AM   #4
schtef is offline schtef  Croatia
Default is it working?
I recently obtained a Philips 614 cd player with the same M50423FP ic. Have you managed to get non oversampled signal from the mitubitshi dsp? Which mode should i try?
Thnx
Old 8th January 2007, 09:53 AM   #5
tubenut is online now tubenut  South Africa
tubenut's Avatar
Would be keen to know as well, have a 614 also.
How does one change modes? Different pins to ground or Vs?
Guillaume
Croak Audio Exploration
Old 9th January 2007, 04:15 PM   #6
Hi schtef,
I haven't manage to set nos mode, yet.
I think, there are connections under chip on the board.
So the DASEL pins have to be desoldered, by air solder,
which i am looking for ....
Old 9th January 2007, 04:23 PM   #7
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Is it possible to set non os mode in Philips CD130 with M50423FP signal processor? Is it possible to set non os mode in Philips CD130 with M50423FP signal processor?
Or just lift the mode-change-legs?
(maybe attach thin wires to the legs for testing)
Arne K
Don't believe everything you think...
Old 10th January 2007, 07:48 AM   #8
Arne K
It's just my idea :-)
Old 10th January 2007, 09:46 AM   #9
First I have to finish my dac. It's still on paper . Then I'll try with the dasel pins. Had the same idea with the pins.
Is it possible to set non os mode in Philips CD130 with M50423FP signal processor?Hide this!Advertise here!
Mitsubishi M50423FP->TDA1543 nonos aparatusonitus Digital Source 18 20th April 2012 05:23 PM
M50423fp & Tda1543a tbklbl Digital Source 4 28th October 2008 08:32 PM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Instruments and Amps 19 15th March 2006 10:15 AM
Help IDing Philips signal transformer planet10 Parts 2 18th August 2004 07:55 PM
Calculating watt requirements for multi-mode/tri-mode operation? Datoyminaytah Solid State 1 14th August 2004 08:43 AM
Copyright ©1999-2017 diyAudio
