Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th December 2011, 09:09 PM   #211
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
You'd be surprised how much influence a good clock has on the sound... A crappy clock signal with lots of jitter doesn't sound nice, you should do a comparison some time.
The Nokia-guy is partially right; but the supply and load cap are the only differences you can see from the OUTSIDE. Inside the can, they are a world of difference.
A crystal will not do much by itself, it is a passive part with two pins (or three, and then it is called a resonator) and needs an active oscillator-circuit to work. This can be a simple CMOS inverter, or a JFET circuit. Basically anything that amplifies. Very often, such CMOS inverters are already integrated in a DAC or receiver IC. The crystal is part of the oscillator circuit and determines the frequency.
A clock on the other hand, or oscillator-module, contains exactly all of the above inside the metal can, so it holds a crystal and the active circuit. It puts out a neat clock signal if you connect is to a power supply and is a ready-to-use device.
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 7th December 2011, 10:00 PM   #212
Thank you very much Ray . Nice homepage you have. I just bought the ACHL-24,576MHZ-EK from Mouser and I allready have a 3,3 V discret regulator.
I have built 3 more of the EZ dacs but the others with clocks from New Class D but I do not think they are good. Other clock I have used is XO XO2 and XO 3 from LC.Audio
Old 7th December 2011, 10:10 PM   #213
I will use your discrete output stage for one of the EZ dacs. I will be back.
Old 8th December 2011, 11:18 AM   #214
6h5c's Avatar
Hi Erlend,
Thanks! Good to hear you like my page.
I don't have any experience with commercial clocks, because I build a Flea if I need one . But one thing I noticed: all these manufacturers speak of jitter and how bad it is and that their clock is x times lower, but I don't see any measurements anywhere. Where are the numbers? So it all depends on how low that jitter actually is in practice. A nice low-noise power supply or a shiny SMA connector won't help with that if the oscillator is bad.
I think the outputstage is a very nice sounding circuit. How are you going to do the I/V conversion?
Ray
Old 11th December 2011, 04:59 PM   #215
Originally Posted by 6h5c View Post
Hi Erlend,
Ray
Passive I thought.
Old 11th December 2011, 05:52 PM   #216
6h5c's Avatar
Hi Erlend,
Passive is possible, but you may have to increase the amplification of the outputstage a bit. A 25R I/V resistor will give you only 200mV; you can lower the emitter resistors in the input stage to as low as 100R for 2Vrms output.
Ray
Old 11th December 2011, 06:24 PM   #217
R 7 and 8 or 5 and 6 ? I have over 20 pcs 389 so I will try to use them on the board instead of 170.
Old 11th December 2011, 06:45 PM   #218
6h5c's Avatar
Oh sorry, that would be R7 and R8. With the CFP-transistors in place that's not obvious anymore
Ray
ezDAC v.1.5 Builders Thread ezkcdude Digital Line Level 349 9th February 2012 07:05 PM
ezDAC Group Buy Interest? ezkcdude Group Buys 302 9th June 2011 01:33 AM
ezDAC chipsets xaudiox Group Buys 0 27th May 2009 06:45 PM
ezDAC clock question M-chen Digital Source 2 7th February 2009 05:52 PM
Page generated in 0.08474 seconds (86.96% PHP - 13.04% MySQL) with 11 queries
