| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Tonight I tried hooking up an SMPS to my Scott Nixon USB DAC instead of the SLA battery which I had been using. I got the SMPS from EBAY after a few reports that it worked well with a Tripath amp. It is good for about 3 amps at 12v.
Before I hooked it up it measured about 12 vdc output. When I flipped the switch to the DAC the DAC power-on LED flashed briefly but the DAC would not show up on the computer. Measuring the output now showed about 4 vdc. If I disconnect the wires to the SMPS and turn it back on I get 12v. As soon as I slip the switch to power on the DAC it drops to 4v. I do have one extra 1000mf cap added to the power input of the DAC. It looks as if the SMPS is going into a protection state when trying to charge up that cap. I could take it off but there will still be another onboard cap to charge. Any ideas? Best, Paul |
#2 |
Recheck the usb dac maybe a "short" somewhere;are the components mounted the right way?Any solder shorts,Power connection correct,Polarity? |
#3 | |
Thanks for the reply. |
#4 |
could be a problem of input capacitance of the dac?
#5 | |
Thanks! |
#6 |
Do you still have the battery connected when you use the smps? What is the normal battery voltage? If the battery voltage is much lower, the DAC may be protected to overvoltage and may see the 12V as overvoltage.
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#7 |
Magneto the Gravity Man
Hi.
Don't forget that some smps like to see a load (ie minimum current.) Andy |
#8 |
If it powers up to 12V without load, then it shouldn't be looking for a 'minimum current'.
Probably caused by the heavy filter caps of the DAC - Charge them up first using the SLA battery, then quickly switch over to the SMPS. If that gets the whole thing working, you've confirmed the problem... Now as to how to go around that... hmmm - charge the filters through the series resistor first, then have a relay short out the resistor after a second or two... ??? Cheers! |
#9 |
what about when switching the supply on, the DAC switch already turned on?
#10 |
Thanks for the good tips.
No battery connected when using the SMPS. First I turn on the SMPS, then I switch on the DAC. A series resistor sounds like a good idea for troubleshooting. Basically I want to compare the sound of SLA vs SMPS. If I like the SMPS I will probably leave it powered up all of the time. If the resistor works I could use a DPDT on-off-on switch so that I had the resistor in line one way and then out the other. Anyway I have some good ideas to try... Thanks! |
| F2 running hot(how hot is hot?) | Aron | Pass Labs | 10 | 13th February 2009 03:42 PM |
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 02:34 PM |
| My first ever DIY Amp up and Running ! | Ebola | Class D | 3 | 12th December 2006 09:49 AM |
| Running-in the UCD 180... | ptwining | Class D | 10 | 12th August 2006 05:19 AM |
| New Ono up and running | Ed Robinson | Pass Labs | 13 | 14th June 2003 06:45 PM |
| Page generated in 0.09945 seconds (81.53% PHP - 18.47% MySQL) with 10 queries |
