| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Has anyone got it right yet to solder BGA devices at home, and would share this information with us?
At Spes Infracta __________________ |
#2 |
I’ve successfully used a Lattice CPLD in a home project. I only needed to connect 20 or so signals so gluing the chip upside down and soldering link wires from the balls to the PCB worked a treat. That device had 1mm ball pitch; I also tried a 0.7mm pitch device but gave up.
Unfortunately, your chances of mounting a BGA the correct way are very slim. We have a manual BGA pick and place machine at work with an optical alignment system (a video camera mounted on a microscope) and that gives a pretty poor success rate. Good luck! David. |
#3 |
Thanks, but no thanks. The device in question would be either 256FBGA or a QFN108 and it would have to go on a pcb.
I guess my best bet would be to either 'stay away from BGA' (hey that has a nice ring to it!) or cultivate a contact at some place like MTech or Walters with the necessary facilities. Stinking IC manufacturers: 1 Determined hobbyists:0 Can we allow this to continue? Cheers John Hope
#4 |
Its not the IC manufacturers to blame, its the customers. With my work hat on I want the smallest device package I can get and BGAs fill that need. So I buy BGA package devices over leaded ones.
But BGAs are not the only non-DIY friendly package. Chipscale packages, 0.5 or smaller pitch leaded packages etc.. are all beyond 99.9% of DIYers. Even with a nice metcal and a mantis they are a nightmare to solder. If you really have to use a BGA I'd start getting friendly with a PCB assembler. |
#5 |
#6 |
Thanks Dave. Very useful info. I knew somebody must have done it.
One of the articles mentions a couple of 'opens and bridges' on fine pitch devices that had to be cleared manually. I guess with BGA FPGA's s there is no recourse to fixups, and it would be a good idea to have as much 'redundant I/O breakouts' as possible so that opens could be fixed by using another pin on the FPGA. With shorts, I guess one can similarly reroute the I/O and tristate the shorted pins. Assuming the short is not between power rails, or JTAG pins or anywhere else really tragic. This all sounds like a good challenge! Cheers John
#7 |
Im making my living by placing BGA's, and other components, so it's a simple thing to do for me
#8 |
Perhaps when faced with a mid life crisis instead of a sports car with a six figure price tag, one could buy an Ersa instead. It's a lot cheaper.
#9 |
rfbrw: Perhaps I'm missing something here, but I don't see the connection between sports cars, midlife crisis and diy'ers figuring how to get BGA devices soldered. Perhaps you have the wrong thread?
CJ900RR: Do you offer a service to guys wanting one or two BGA's soldered? Tell us more. Cheers John
#10 |
I have learned to solder the small pitch stuff... against my wishes. And yes, Metcal is your friend.
I don't wish to discourage anyone... but BGAs?
| Page generated in 0.09632 seconds (76.88% PHP - 23.12% MySQL) with 10 queries |
