Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
first try cd-rom + 1543 dac
Old 23rd September 2006, 12:02 PM   #1
senderj is offline senderj  Hong Kong
Default first try cd-rom + 1543 dac
Tried to use cd-rom drive plus a NOS 1543 dac to bulid cd player. The controller + cd-rom drive works find when use analog output. But when connect the SP/DIF to this 1543 dac
http://www.pbase.com/billyflorentino/image/19056296
the controller freeze with message "Looking for IDE". Disconnect the dac, the cd-rom driver plays normally. Any idea what's wrong?
Old 23rd September 2006, 04:05 PM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Which kind of controller are you using???
Old 24th September 2006, 01:35 AM   #3
This one:
http://www.cdream5.com/htm/PDF/CDC3_SCH_V5.rar
Old 24th September 2006, 02:26 AM   #4
Leolabs's Avatar
Then which version of firmware are you using???
Old 24th September 2006, 03:11 AM   #5
Version 3.2
Old 25th September 2006, 02:23 AM   #6
Leolabs's Avatar
Never know there is such a problem.Have you try with other DACs???
Old 25th September 2006, 06:21 AM   #7
MCLL is offline MCLL  Hong Kong
MCLL's Avatar
What brand name CD-Rom you connect?
or
using other CD-Rom?
Old 25th September 2006, 08:56 AM   #8
I don't have other dac to try.
I did further test on the dac with a dvd player's coax out. It didn't work also. From the link, it works with the author. And I also saw some similar schematic (same 75R at input, using 8412 or 8414 with 1543, different output RC network) DAC on other web sites and the authors also have success. I've check my connection over and over again and didn't spot anything wrong. What is the most likely area where I made msitake? What would you check first if you are in such situation? Please help.
Old 25th September 2006, 10:26 AM   #9
PetrL is offline PetrL  Czech Republic
"same 75R at input"
The CD-rom has TTL output level, so no 75R in parallel! Just leave it out.
By the way, soundwise, using CD-rom's digital out is waste of time (I wasted it already).
Old 25th September 2006, 10:27 AM   #10
MCLL's Avatar
I have build a DAC also using CS8414 & AD1852 connect to my CD-Rom Player. No any error found. And then, Try to connect dvd-player and no any error found.
first try cd-rom + 1543 dacHide this!Advertise here!
Diy-dac 1543 Tolu Digital Line Level 112 9th September 2009 01:20 PM
TDA 1543 - How hot? pixpop Digital Source 11 12th January 2006 10:37 PM
DIY USB-1543 Dac Kit Help recca Digital Source 7 26th August 2005 06:55 PM
Tda 1543 Chris Digital Source 5 23rd October 2003 11:39 PM
Copyright ©1999-2017 diyAudio
