| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello!
Some time ago I made some considerations about filters and I found the following filter interesting: A subharmonic series of cosine bursts with alternating sign: sum(-(-1)^i/i cosburst(x/i),(i,1,infinity)) cosburst(x):=cos(x)+1 for (x,-pi,pi), else 0. would give an infinite impulse response that could be clipped, preferably at zeros. The response is not strictly periodical, the distance between the zeros increases towards the periphery. The frequency domain of the stopband is aperiodical. My questions: Is this new, and would this behaviour be an advantage compared to conventional filters? Regards, Oliver |
#2 |
Banned
I like the Kaiser-Bessel filter.
#3 |
Thread refresh.
Is an aperiodical frequency response in the stop band an advantage? |
#4 |
Hi Olivier,
Are you able to give simple math formula of your filter like Y =K1 * S1 + K2 * S2... where Kx are constant coefficient and Sn, previous and next input sample. I could insert this filter in my DAC Simulator to have response to your question. Eric |
#5 |
Hello Eric!
I converted the (finite) impulse response into numerical form using Mathematica and used the numerical integral to calculate the frequency response. So I already know the filter has this aperiodical behaviour. What I am asking myself is: Does this have a sonical benefit in terms of less audible filter ringing? But if your simulator has some useful features I can`t easyly implement in Mathematica I can calculate the filter coefficients. |
#6 |
Or is it more desirable to have zeros at multiples of the Nyquist frequency in order to get least possible aliasing at low frequencies?
#7 | |
Hello Oliver,
The simulator is written in C#, (µsoft .NET 2005) it is not and ended project, I add function to have wide comprehension of digital audio. If you are interested in, we could share this project. Final version will be free to download. Eric |
#8 |
On the actual DAC simulator, I implement a simplified digital filter like you could find in Wadia and of course standard Sin(x)/x filter.
#9 |
I will mail you the coefficients. How much oversampling? 8x? 16x?
Center on a sample or between two samples? |
#10 | |
Hi Olivier,
Eric |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| Can Zaphs notch filter be used without the BSC filter? | GuyPanico | Full Range | 0 | 21st July 2007 01:27 AM |
| Just one big filter cap or more smaller filter caps ... | beppe61 | Power Supplies | 2 | 18th July 2006 05:46 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| chassis-mounted filter or IEC plug filter | jarthel | Solid State | 7 | 11th March 2002 10:17 AM |
| Page generated in 0.09547 seconds (81.87% PHP - 18.13% MySQL) with 11 queries |
