Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th September 2006, 08:41 AM   #1
Default pioneer dv737 fault
i have a 737 damaged.when insert a dvd the display light off
and nothing happens.when insert a cd audio the display light off
i can start manually but the sound pop e crash.Any idea?
laser or power supply?.
Old 16th September 2006, 01:29 PM   #2
clem_o is offline clem_o  Philippines
Could it be the spindle motor / drive electronics to the spindle motor? Every time you insert a disc, one of the first things the player will try to do is spin-up.
Open the cover and see what it does when you load a disk...
Cheers
Old 18th September 2006, 06:14 AM   #3
with dvd the motor doesnt start ,with the cd starts but not the
autoplay i have to give the play command when the song ends
the next command to go on.the sound is much distorted.
Old 18th September 2006, 07:07 AM   #4
Laser focus may be off calibration - seems it has difficulties seeing a DVD and reading CDs properly.
Could be that the laser is weak already - if the player has been used for a long long time it may be that the laser assy is nearing 'end of life'.
Cheers
Old 18th September 2006, 07:32 AM   #5
anyone knows if it is possibe changing the mecanics with a
dvd rom or what model is the originel into the pioneer?
Old 19th September 2006, 02:05 AM   #6
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
About the spindle motor,it's possible,seen that both are using brushless 3 phase motor,but check for wiring.About the lens itself,you need to contact Pioneer for their own laser pick up unit.
Just wondering what kind decoder chipset inside???Pioneer own design or the more popular Taiwan's Mediatek chipset???
Pre amp fault Addolff Parts 4 6th January 2008 01:55 PM
Quad 306 fault steevo Solid State 1 19th May 2007 05:27 PM
nad 304 annoying fault sollerbeen Solid State 14 17th November 2006 06:51 PM
cd6000 fault goodlife Digital Source 11 28th April 2006 06:31 PM
Buffer Fault pete.a Chip Amps 17 8th September 2004 08:10 PM
Page generated in 0.07543 seconds (77.50% PHP - 22.50% MySQL) with 10 queries
