| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi there!
I've got an modified Teac vrds10se with lcaudio clock, all new capacitors and lm 6171 opamps. I also got an parasound 1500 DAC. So what I did, I put out the DAC board, put in 2 shuntregulators from tentlabs and changed the lcaudio clock to tentlabs xo-2. Now the sled from the transport can go out and in, the cd is pushed on the clamp but when I push the play button the clamp/disc won,t turn. Does somebody know what I did wrong? The change from the clock is the same I think, or is it not? Thanks allready, Teake |
#2 | |
Hi You have changed 2 things in one time, so it is kinda hard to distinguish now Did you check the output voltage of the shunts ? best |
#3 |
Thanks for the reply Guido!
I got on the the positive 5V 3,6V and on the negative 5V 9,1V on the out pins. Grtz Teake. |
#4 | |
then they are connected wrong, and or from the +5 too much current is drawn Mail me seperately and I will send you the application note for the shunts, for some reason I cannot upload that to my web (where other PDF files work flawlessly) best |
#5 |
Hi again!
I soldered the shunts again measured on the positive shunt in 11V on the out 4.9V, on the negative I measured on the in 11V and on the out 0.3V. I measured between gnd-In and gnd-Out. So what's going wrong here? Can anybody tell me. Thanks for the answer. Grtz Teake ps measuring between In and Out gave ont the positive 5.7V and on the negative 10.7V The old ones were 78M05 and 79M05 |
| TEAC VRDS-10 vs VRDS 25X | Pani | Digital Source | 12 | 3rd April 2011 04:03 AM |
| VRDS 20 problem -isolation | Miniwatt | Digital Source | 8 | 16th December 2008 04:48 AM |
| VRDS 25 and VRDS 25X: how to tell the difference? | dubkarma | Digital Source | 1 | 20th August 2006 03:44 PM |
| Teac VRDS T1 Problem...does not open | Fimax | Digital Source | 5 | 6th November 2005 05:11 PM |
| TEAC VRDS-10 Problem | DavidY80 | Digital Source | 0 | 24th June 2004 02:02 PM |
| Page generated in 0.08530 seconds (77.93% PHP - 22.07% MySQL) with 10 queries |
