Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th September 2006, 12:20 PM   #11
adhoc is offline adhoc  Australia
adhoc's Avatar
Originally posted by mrjam
Ground loops aren't generated by single shields connected each indipendently at one single gnd point.
ah... star grounding. i get it.
jitter critter.
Old 12th September 2006, 01:29 PM   #12
tubenut is offline tubenut  South Africa
tubenut's Avatar
What about resonance? Would these heatsinks not work as nice tuning forks stuck to the top of the dac chip inducing mechanical vibes?
Heard somewhere that the internal sink on the TDA1541 can be excited to resonate hence Naim took some trouble to specifically isolate the 1541 from vibration on the original CDS...
Just hearsay.....
Guillaume
Croak Audio Exploration
Old 12th September 2006, 02:58 PM   #13
Sonusthree's Avatar
Surely the heavy copper and the I.C. would have different resonant frequencies which would help avoid resonance.
Also I think the epoxy should act as a form of constrained layer damping.
Martin
Old 12th September 2006, 02:59 PM   #14
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
No, just individual grounds in close proximity to the chip.
Andy
Old 12th September 2006, 03:44 PM   #15
Looks like a good idea Ruach, esp. for the old Philips chipset (SAA7220 / TDA1541) which run hot - I must find some and try this
Yes they did - in fact all their CD players (except the CD3, 3.5, 5 and 5i/ 5x) have sprung suspension for the PCBs!
Old 13th September 2006, 01:36 AM   #16
Ruach is offline Ruach  Singapore
Hey guys,
Do try it out and see if this tweak works for you. It is cheap and it is very easy to implement.
You can either ground it or if you are lazy like me, stick it on the chips and do the grounding another time.
The copper heatsinks are about 2.5 to 3mm thick and they are quite heavy (relatively to the aluminium heatsinks).
The fins are too short to act as a tuning fork and even if this is the case, I am sure that you guys can find a way to damp it.
In my crude experiments based on a handphone as the generator of EMI/RF, I found that thicker copper sheets provide better protection from EMI/RF.
FYI, the Arcam Black Box 1 and 2 have sprung suspension for their TDA1541A chips too.
Old 23rd September 2006, 10:59 PM   #17
Sonusthree's Avatar
Well,
My Thermaltake copper heatsinks arrived today but they are diferent to the ones pictured above. The ones that I have bought have a square base and unfortunately are pretty incompatible with the I.C.'s in my CD player. Especially as they are SMD devices.
I have attached 2 of these across four regulators that lay flat on the PCB. So that 2 regs share 1 heatsink. I know it's probably a waste of time and money but what else can I do with them?!!
They are pretty cool things in the flesh though and are surprisingly heavy and rugged for their size. The adhesive sticks fairly well but leaves the sinks able to be twisted slightly.
I'm pretty sure they're going nowhere though unless I drop my player!!
If anyone wants to get some of these then just make sure they are the right version.
S3.
Martin
All copper heatsinks? Dominick22 Chip Amps 40 17th February 2006 06:55 AM
PC processor copper heatsink for amp cooling ? Bernhard Solid State 5 18th December 2005 01:20 AM
Copper block heatsink C/W Nabetse Chip Amps 5 8th October 2005 07:26 AM
large copper heatsink raidfibre Swap Meet 1 8th September 2005 01:48 PM
Copper/Aluminum heatsink - yay or nay? thylantyr Solid State 36 1st July 2004 11:11 PM
Page generated in 0.10609 seconds (74.78% PHP - 25.22% MySQL) with 11 queries
