Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
KSS213C LASER UNIT installation ?
Old 26th October 2010, 03:28 PM   #31
robber222 is offline robber222  United States
Send a message via Yahoo to robber222
ok... last nite I removed the tray successfully. Turns out the control cam had slipped out of gear. I think it's still in good shape... three gear teeth still there. Is that all there should be? I put the control cam back into the "eject" position, put the drive gear (#5) back into place but still having problems. I didn't note the starting position of the drive gear upon removal, and I've not been able to figure out the correct position or sequence of the gears... it doesn't work properly when I push the tray back in.
Gabe
Old 1st November 2010, 03:24 PM   #32
Default OK... IT WORKED!
I had removed the entire transport and was trying to put the mechanism (along with the tray) back into the player and couldn't get the drawer to the tray gears to work properly. I lined the gears along with the "cam" as if the drawer was in eject position and installed it.. without the tray. I pushed the tray in with the machine powered-up.... and BAM! It works! Thanks for your tips on removing the tray!
Gabe
KSS213C LASER UNIT installation ?Hide this!Advertise here!
Sony KHS-130a laser unit hihopes Parts 8 28th January 2012 07:42 PM
nad 510 laser unit pipedreams Digital Source 2 8th January 2009 10:27 PM
Which laser unit for HK HD740? hiwiho Digital Source 0 26th May 2007 03:45 PM
cd17 ki laser UNIT sq225917 Parts 2 14th December 2005 07:30 PM
Laser unit used in Yamaha CDX-700 Dumbledore Everything Else 8 7th December 2005 02:06 PM
