Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
KSS213C LASER UNIT installation ?
Old 12th September 2006, 02:40 PM   #21
fender62 is offline fender62  United Kingdom
installed lens now motor not spinning disc at all not reading err
draw opens closes ok
Old 12th September 2006, 03:30 PM   #22
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Oh dear.
OK checklist time.
1. Is the short really cleared?Did you check with meter or magnifying glass?
2. Are all connectors in place?
3. Is the flat data cable in the right orientation? That is the tinned side facing metal fingers of connector?
4. Is the flat cable inserted perpendicularly into the connected and not slanted at an angle?
Can you hear the laser or see the laser head moving up and down trying to focus? Will wait for reply.
Old 12th September 2006, 03:54 PM   #23
success mate. what i did wrong was i didnt have the chassis and spring set correct i redid it properly, i see what people mean by taking pics before you dismantle i recommend this really anyone who tries this. and many many thanks my 160 cd player works like new wow!!!
Old 12th September 2006, 04:03 PM   #24
Congratulations you are now a DIYer.
Old 12th September 2006, 04:11 PM   #25
would this repair also apply to a dvd player lens, the lens only cost a tenner a repair man wanted 50 or 60 pound iwas quoted.
as isaid i only paid a 20odd for the cd player of flea-bay
Old 12th September 2006, 04:19 PM   #26
Yes.
Old 12th September 2006, 04:24 PM   #27
thanks when that goes ill do the same brilliant saved me a mint
and so with your help, i was nervous but though id have a go
bit like a surgeon.
Old 24th October 2010, 09:08 PM   #28
robber222 is offline robber222  United States
Send a message via Yahoo to robber222
I am replacing the laser in my NAD C542. All seemed to be going well until I put it all back together and powered it up. Nothing happened. The part of the mechanism that lifts and then spins the CD is just sitting there. I can see that when I remove the laser chassis, I can see that the gears on the drawer are supposed to engage the control cam which in turn lifts the laser chassis upwards to engage the CD. The control cam is not being engaged by the drawer gears. I could get a better look at the gears IF I could remove the cd tray, but I cannot seem to figure out if that's possible. I need help! I don't wanna toss this player in the trash! Thanks! I am attaching a link to the service manual also.http://hifigoteborg.se/nad_manuals_self/C542.pdf
Gabe
Old 25th October 2010, 01:06 AM   #29
Bill Fuss is offline Bill Fuss  United States
RIP
The pic in the manual is pretty crappy, isn't it.
To take the tray out first remove the switch pin(13) on the tray, then travel the tray out as far as it will go. Look at the base on both sides right by the tray, there is a curved plastic spring on each side that prevents the tray from falling out. Gently spread the springs a little and the tray will come out.
There is a little plastic cover over the belt that is probably the cause of your problem. Pinch the locking tab then slide the cover sideways to remove it
Old 25th October 2010, 01:39 PM   #30
thanks Bill! I will try that tonite when I get home. I will post the outcome as soon as possible. Keep yer fingers crossed for me. I was lucky with mine for a long time since mine would usually only refuse to play discs and spit out the "No Disc" error if I was starting up the player "cold". But, if I left the player on "standby", it would work flawlessly about 90% of the time... so I left it alone. But the other day it was giving me a headache, so I ordered the lasser chassis unit online for $5.
Gabe
KSS213C LASER UNIT installation ?Hide this!Advertise here!
Sony KHS-130a laser unit hihopes Parts 8 28th January 2012 07:42 PM
nad 510 laser unit pipedreams Digital Source 2 8th January 2009 10:27 PM
Which laser unit for HK HD740? hiwiho Digital Source 0 26th May 2007 03:45 PM
cd17 ki laser UNIT sq225917 Parts 2 14th December 2005 07:30 PM
Laser unit used in Yamaha CDX-700 Dumbledore Everything Else 8 7th December 2005 02:06 PM
