Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th September 2006, 07:57 AM   #1
tubee is offline tubee  Netherlands
tubee's Avatar
Default Bessel filterdesign
Hi all
I modified a Philips CDP304mk2 with Kwak clock, OPA2132 opamps and a lot more. Sounds good, but the treble has sometimes a sharp edge. I wondered if it is possible to exchange the standard (butterworth?) filter around opamps to a more phase-lineair Bessel type.
The original Philips schematic shows a 2N cap paralleled with 1k8 in first feedback loop/opamp. Two 2k4 resistors to non-inverting input with inbetween 2.2N and 470uH in 2nd feedback loop of 2nd opamp.
I have been looking on some sites, eg: http://www.analog.com/Wizard/filter/.../#responseType
Filter free offer a download too. Too complicated for me. My electronics education was a very long time ago,(though having a good grade for it
Has someone a suggestion and hints to calculate the right part values?
Thanks.
Daisy Bell
Old 10th September 2006, 05:37 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
you could try mailing 6H5c. He has done a lot of modelling on the outputs of the CD63 range.
Old 10th September 2006, 07:50 PM   #3
jackinnj's Avatar
try this;
http://www-users.cs.york.ac.uk/~fish...lter/trad.html
and there is a great freeware program from NuHertz -- Filter Free -- http://www.nuhertz.com/
Old 10th September 2006, 08:05 PM   #4
tubee's Avatar
Thanks Poynton and Jackinnj for helpfull answerings.
Will try & calculate Jackinnj's reffered website first, if i cannot succeed search an answer on 6H5c.
Daisy Bell
Old 10th September 2006, 08:50 PM   #5
poobah is offline poobah  United States
poobah's Avatar
tubee,
Keep in mind a Bessel filter is not as efficient as a Butterworth. You will need more stages of filtering to accomplish the same task. Bessel will give better phase response... there is much debate as to whether this can be heard though.
Old 10th September 2006, 09:01 PM   #6
tubee's Avatar
Hi Poobah, thanks for the info. Because i kept the SAA7220 on its place(this time), the sound has a once in a while a sharp edge, also because of the opamp upgrade: the OP2132 sounds some laid back, this is discussed here on diyaudio more often. But i discovered DVD has an sharp edge sometimes too (but some more detailed because of 24/96 resolution). This could be a digital phenomenon then.
Maybe the sharp treble can be some sweetened by a roll-off of the less steep bessel. My pre amp and fet-tube poweramp have tubestages, can take some HF i think.
Daisy Bell
Old 10th September 2006, 09:12 PM   #7
poobah's Avatar
Hmm,
You have to be your own judge of course. After 35 years of playing in bands (off and on), I can tell you many harsh sounds are very real. Listen to an 8 year old with a violin!
Whether you can change to Bessel may depend on how your filter is layed out now. Can you post the schem of your Butterworth?
Old 11th September 2006, 07:38 AM   #8
tubee's Avatar
There is something else going on: i have a small 30-40 dB dip in my hearing on +/- 4000hz (my father had also) And some attenuation again to 8 / 10 K. So allmost all "straight level" tweeters sound harsh to me, even sitting sideways(eg coaxial Kef speakers from my friend) But at this moment hear classical music with a Kenwood tuner: no harsh sound, but nice "articulated" treble.
The schematic, yes ehm, threw away the scanner, so have to find a way to show.
Filtering is standard like most 16bit 1541 players with a dual opamp.
Daisy Bell
Old 25th September 2006, 08:53 PM   #9
tubee's Avatar
I just added a small 4uH ferrite coil between TDA1541 and the first stage of IV. This helped allready, some sharpness is gone. The filter itself is left as it is.
I don't want to get rid of the highs, but only the"S" sounds in voices.
Daisy Bell
Old 11th February 2007, 06:21 PM   #10
tubee's Avatar
Very long time later, but here is the schematic of outputstage from CD304MK2 (Have att last that needed serv. manual)
Can somebody confirm what filter is used? (bessel or butterworth)
Thanks!
Daisy Bell
The Bessel Array Patrick Bateman Multi-Way 31 22nd November 2011 10:30 PM
An even better Bessel filter jackinnj Multi-Way 0 5th April 2006 01:14 PM
Bessel Array feds27 Multi-Way 5 18th August 2005 11:23 PM
Butterworth or Bessel metal Chip Amps 1 26th June 2004 08:48 PM
filterdesign revelator aaronboumans Multi-Way 7 2nd December 2003 05:35 PM
Page generated in 0.10461 seconds (79.41% PHP - 20.59% MySQL) with 11 queries
