Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd September 2006, 12:00 AM   #1
Default Kenwood DP-X9010 Transport issues
Hi all,
I have recently bought a Kenwood DP-X9010 transport for use with my Marantz CD-7. It worked fine when in use by the seller. I hooked it up to my CD-7 and the signal is locked, the disc reads (even very bad TOC discs are read) and music is played (not distorted). BUT, there is an extra noise comming from the speakers (DAC) in the form of a crackling/skipping noise (laser is actually in very good order, so no laser skipping, just sounds like it).
This problem occurs on both toslink and coax.
Any ideas?
Thanks,
Ramon
{Marantz CD-7 Guido Tent Clock ---> HMS Sestetto MKII XLR ---> Electrocompaniet ECI-4 ---> Kimber 8TC ---> Eros MKII DIY}
Old 3rd September 2006, 05:15 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Is the Kenwood transport using Sony laser mechanism?It could be tracking problem,try other cd disc.May have to live with it.This is a "known" fault even on Sony sacd players.Then again since this is a used unit the laser has aged and may be going out.
Old 3rd September 2006, 11:35 AM   #3
Has problem with al the discs.
But it even reads all the dirty discs. So laser is not the problem.
Old 8th March 2007, 05:27 PM   #4
smutley is offline smutley  United Kingdom
I have one of these units. This unit has an adjustable laser. The laser is preset to a low output - one of the reasons that they rarely give-up. It will read most discs but sometimes it will present a fault like you describe. Its a real fiddle to adjust the output, you need to adjust a little pot at the base of the laser. You will likely need a mirror to find the pot first. I think from memory that is on the tray centre side of the laser. It needs to be something the right size -
be careful as it will be easy to damage. Try to adjust it in increments and use a disc which definitely sounds bad. This may sort your problem. Before this..I know its obvious, but have you tried cleaning the laser. Once you get it going you should think about clock/PS mods - it realy makes a difference to these machines.
better to light a single candle than stumble in the dark
Old 9th March 2007, 08:56 AM   #5
Bernhard's Avatar
Hi, I would first try adjust tracking and focus gain and offset etc. then turn up laser power pot on laser clockwise in smallest possible steps.
Did that for a friend who had the same problem.
Old 22nd April 2007, 11:48 AM   #6
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi guys. I know this is an old thread but does anyone know which model of laser is used in this please?
Lee.
Old 23rd April 2007, 04:18 AM   #7
Send a message via AIM to quantran Send a message via MSN to quantran Send a message via Yahoo to quantran
The laser unit seems to be custom made for Kenwood based on Sony KSS152. The body is similar to KSS152 but the cable is different.
KSS152 can be fitted with some modification as I have seen but don't ask me how.
You can see part # in these photos
http://www.diyaudio.com/forums/attac...amp=1161513442
http://www.diyaudio.com/forums/attac...amp=1161513337
Quan Tran
Old 13th August 2007, 05:51 PM   #8
Bernhard's Avatar
I have the 9010 here and it sounds very different compared to other players/transports.
Sound is very liquid but edges seem to be rounded off and perhaps details / texture lost ???
The unit has already Black Gates in the PSU.
I would like to hear opinions from 9010 owners.
Thanks.
Old 16th August 2007, 03:32 PM   #9
Agreed with you opinion. I have installed a new XO clock in my 9010. Treble improved a bit. This machine has typical Sony sound. The bottom end is much heavier than other machines. I prefer my moded Marantz cd-53 mkii as a transport. I guess this is due to the decoder chip made by sony
I think yours has been moded by the previous owner. No BG at all among the original caps.
Cheers
Quan Tran
Old 16th August 2007, 03:41 PM   #10
Thomo's Avatar
Does anyone have any more info on how to mod that Sony laser for use in these machines? I have one of these transports sat on the shelf here and it's useless. The laser is completely shot and I cannot source a replacement anywhere.
Any help will be greatly appreciated,
Lee.
Looking for Laser Unit for Kenwood DP-X9010 krishu Digital Source 20 14th February 2012 06:00 PM
Kenwood DP-X9010 and CD-R Rien Digital Source 1 1st June 2009 07:33 AM
Kenwood KAC-X811D Current issues shawnschuldt Car Audio 5 23rd September 2008 02:17 PM
Page generated in 0.10418 seconds (79.95% PHP - 20.05% MySQL) with 10 queries
