Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd September 2006, 09:29 PM   #1
Default MN672213 I2S output
Hi
does anybody know what format of I2S use this Panasonic chip.& want to connect TDA1543 dac.
Old 3rd September 2006, 02:00 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Since this is a Japanese IC it will probably use the Sony format and the easiesy way is to use TDA1543A.iF You use tda1543 you need a circuit to make I2S( philips ) signal compatible to tda1543.That is EIAJ to I2S.Search the threads and you will find the circuit.
Old 15th October 2006, 09:46 PM   #3
& tried TDA1543A but sound level is very low.Does it problem with I2S formats or TDA1543A don't work with Kusunoki schematics?
Old 16th October 2006, 01:35 AM   #4
TDA1543 = I2S
TDA1543A = EIAJ
MN672212 =I2S out?
Old 16th October 2006, 05:37 AM   #5
& didn't find MN672212 datasheet .& connected via I2S 3 pins.With TDA1543 there is no sound,with TDA1543A sound level very low,but nice. & think maybe TDA1543A have protection diodes at the output like most parallel dacs.
Old 16th October 2006, 07:55 AM   #6
Here is Kusunoki's single tda1543 dac schematic
For you to see.Hope this helps.
Old 26th October 2006, 08:59 AM   #7
Vil is offline Vil
Vil's Avatar
there is no different formats for I2S , another formats are named left justufied and right justified , please look to picture , hope that will help .
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.08786 seconds (75.65% PHP - 24.35% MySQL) with 11 queries
