I2S Problems - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th March 2003, 04:47 AM   #41
Do you have the datasheet for the EP7212?. If not the datasheet for the EP7212 states that the format for the DAI (Digital Audio Interface) is a subset of the I2S format. It is fixed at 44K1 and has bitclock of 128Fs yielding 128 bit clock cycles per L/R frame. Data is MSB or Left justified without the one cycle delay associated with I2S. There would appear to be a conflict between the text and the diagram as regards LRCLK. The diagram shows LRCLK=H as signifying L channel data but the text states otherwise.
ray.
Old 18th March 2003, 05:28 AM   #42
I haven't been able to locate the EP7212 datasheet until just now. I will have to read through it. So it sounds like maybe the two (EP7212 and CS8420) are incompatible? I have tried all the formats the CS8420 and CS8405 support and none of them work right.
I'll still try some resistors, but I don't think they will help.
Thanks,
Stu
GFA-565 problems ben62670 Solid State 5 14th August 2008 06:36 AM
HK AVR 335 Problems utjay2008 Solid State 0 21st October 2007 02:26 AM
Sub Amp Problems Thanks! crippledchicken Solid State 2 10th January 2007 06:17 PM
JLH problems serosmaness Solid State 11 2nd November 2004 06:17 PM
RFI problems laz Solid State 3 21st February 2004 07:06 AM
Copyright 1999-2017 diyAudio
