| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello to all,I am going to build a new output stage for a crappy technics cd that I have,and I going to build a separate miniboard with this stage that I will put into . and I going to put a separate power supply for this board (into the cd too)
I going to use two opa 627 that I have around (instead of the 4560 that have originally do you think I have to put a low pass filter before the opa627 ??? which fq cut? 120 Khz? Thanks for your time Best regard |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Cambridge Audio CD5 output stage (circuit diagram) | 316a | Digital Source | 0 | 15th May 2007 04:57 PM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Audio Note DAC4 SRPP output stage problems! | bbakota2000 | Tubes / Valves | 5 | 12th June 2005 12:25 AM |
| Page generated in 0.06509 seconds (71.32% PHP - 28.68% MySQL) with 10 queries |
