| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Anybody knows about commercial products which use PCM2706 or PCM2707.
I would like to buy one of this and modify to use as usb -> i2s interface to feed my diy dacs. I built myself shuch a device with a pcm2707 and it works, but sometimes it stop playing on mains noise caused by turn on or turn off of nearby devices such pre, ampli, dac and i have to reboot the pc. I circumvented the problem improving the mains filtering and eliminating turn on - off click and pop in my pre and ampli, but i never completly understood/solved the problem in the diy pcm2707 circuit. So this is two question thread: 1) which commercial products with pcm270x? 2) which kind of problem/solution in my diy pcm2707? For 2) i will post the circuit schematics and layout. ciao andrea |
#2 |
Schematics and layout.
For the pcm2707 i used an adapter from TQFP-32 to four 8-pin 0.1 spaced sockets as you can see from the image. The layout has been only used as an aid to mount the components on a protoboard with blu wires soldered bottom an red ones top, and so is unusable to do a real pcb, for this purpose i am thinking to design a good layout and send it to olimex or others that make this kind of service. I appreciate any kind of suggestion for this. ciao andrea |
#3 |
ooooops
#4 |
hi!why don't you order samples of pcm2902?(or pcm2906)?
ciao
#5 | |
Because pcm2902-06 don't have i2s out, only spdif and i already have one sample of 2707 which i used in the circuit of posts 2 and 3 and it works but with the problem explained in post 1. ciao andrea |
#6 |
so it could also be a replacement for cs8414 receiver?
#7 | |
Yes, if your source have an usb port (tipically a pc full of mp3, ogg, wav, ... your preferred OS and your preferred mediaplayer). No, if your source is a CD player with s/pdif out, in this case you can get rid of cs8414 receiver getting i2s directly from the Cd player (you need a service manual with schematics to see where you can get i2s). ciao andrea |
#8 |
sure, but pcm2902 allow the conversion from spdif to usb, and that's what i want to do, but some people say they tried without results...
#9 | |
I am not interested in the conversion from spdif to usb so i did not try with pcm2902, you can look at this: http://hepso.dna.fi/misc/pcm2902/PCM2902_usb_dac.html in the pdf on the "schematics" link you can see a connector "P4" with DIN and DOUT, these are spdif in and out at logic level, to convert to have real spdif you can use simple circuits explained here: http://www.epanorama.net/documents/audio/spdif.html ciao andrea |
#10 |
I have a PCB that uses the 2707 to get I2S out. You could certainly leave off most of it and sinply take the I2S signal from where the 1543 usually goes.
http://www.ecp.cc/HPDAC.html |
| PCM2706/PCM2707 Question | bacworth | Digital Source | 2 | 20th July 2010 02:28 PM |
| how does the UCD400/LCaudio compare with commercial Class D products? | greg filip | Class D | 2 | 13th May 2005 07:19 AM |
| Which commercial products use LM/TDA/OPA chip amps ? | percy | Chip Amps | 6 | 14th January 2005 04:05 AM |
| Power Opamp Chips in Commercial Products | krishu | Chip Amps | 22 | 20th November 2003 03:09 PM |
| Page generated in 0.10532 seconds (77.60% PHP - 22.40% MySQL) with 11 queries |
