Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th August 2006, 10:38 AM   #1
Danko is offline Danko  Hungary
Default PCM2702 noise sensitivity
Hello!
I have built a PCM2702, based on guzzler's design:
http://www.mellowparenting.demon.co....er/usbdac.html
I have modified it a little bit: I removed the step-up converter.
The problem is, that when I turn off my soldering station (just a simple transformer and a weller soldering iron), then the PCM2702 "freezes". Then I turn off the PCM2702's power supply, and then back, the computer won't play. I have te reboot the entire PC.
The same happens, when I use a small transformer to power the IC, or a 9V battery, to power this IC.
After this IC, there's a tube current buffer. Maybe, some noise, or disturbance is coming through this tume circuit, when some noise is on the mains?
Have anyone experienced such problems?
Best regards, Danko
Old 22nd August 2006, 08:14 PM   #2
UP! :-)
Maybe, noone has experienced such things, that I had... :-)
Best regards, Danko
Old 23rd August 2006, 11:23 AM   #3
jeff mai's Avatar
Default Not much help...
I have the same PCB and I had the same problems. It was 100% stock so at least you can say it isn't the tube buffer circuit.
The 2702 would lock when certain nearby appliances were switched on or off. I didn't have to reboot though. Just switched the DAC on and off and it would come back.
I never solved the issue and I don't use the DAC any longer so I can't really help. I suspect the glitch causing the problem comes through the computer's USB power supply. You may not use it for power but I believe the circuit still uses it for some purpose.
Maybe link a schematic so others can have a look? I don't remember the details of it.
driver sensitivity vs system sensitivity bvan Full Range 12 5th November 2007 07:57 PM
Sensitivity match in a 3-way system? all of equal sensitivity? or bass is 6db more? rhythmdiy Multi-Way 5 5th November 2007 11:33 AM
PCM2702 on / off noise Douchekop Digital Source 2 16th May 2005 10:29 AM
Pcm2702 Usb-dac 00940 Digital Source 47 24th January 2005 04:36 PM
Pcm2702 Usb Dac sugano Digital Source 9 27th May 2003 06:37 AM
Page generated in 0.07415 seconds (76.51% PHP - 23.49% MySQL) with 10 queries
