Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
BA6353S info wanted
BA6353S info wanted
Old 11th August 2006, 03:57 AM   #1
anatech is offline anatech  Canada
anatech's Avatar
BA6353S info wanted
Default BA6353S info wanted
Hi All,
I'm troubleshooting an Audio Alchemy CD drive. I've found a couple problems and have the unit mostly working. I hate mostly working.
I would love a PDF datasheet of the BA6353S. It's labeled Yamaha and numbered as a Rohm part. It's a servo controller in a DIP package. Information is scarce.
The problem is that the head will not home to the beginning of it's travel. If you back it up using the gear, it'll then read the disc and play fine. Otherwise it just sits there drooling.
-Chris
Old 11th August 2006, 10:00 PM   #2
anatech's Avatar
BA6353S info wanted
Hi again,
I think the Yamaha Part# is XC488A0 - could be wrong. Yamaha did put out a couple semiconductor books referenced to their numbers. Of course mine went with my shop.
-Chris
Old 9th December 2011, 09:19 PM   #3
dimon68 is offline dimon68  Ukraine
dimon68's Avatar
Yamaha XC488AO datasheet and application note, data sheet, circuit, pdf, cross reference, pinout | Datasheet Archive
Old 9th December 2011, 09:29 PM   #4
dimon68's Avatar
Arrow XC488AO = (BA6353S)
Old 11th December 2011, 02:12 PM   #5
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by anatech View Post
Hi again,
I think the Yamaha Part# is XC488A0 - could be wrong. Yamaha did put out a couple semiconductor books referenced to their numbers. Of course mine went with my shop. -Chris
On two images of this IC-type there is to read both - have a look to the attachment.
Here some URLs.
IC XC488AO=BA6353S [ICXC488AO] - R0.00 : Pro-Tec, Your Professional Electronics Supplier!
BA6353S datasheet, ba6353s series data sheet pdf,BA6353S picture,BA6353S manual ,ECONOLINE: RB & RA - Dual Output from a Single Input Rail- Power Sharing on Output- Industry Standard Pinout- 1kVDC & 2kVDC Isolation- Custom Solutions Available- UL94V-
Please note additional: "XC488A0" isn't the same than "XC488AO" !!!
BA6353S info wantedHide this!Advertise here!
Threshold NS-10 and M1 info. wanted Deoreo Pass Labs 88 20th May 2008 07:59 PM
Info on SM042 wanted JonHarrison Solid State 4 30th January 2007 01:56 PM
Enclosure info wanted mikee55 Parts 2 27th January 2007 11:44 PM
Val MP 211 info wanted Miniwatt Tubes / Valves 11 17th April 2005 11:59 AM
B&W DM7 info wanted Jerry T. Multi-Way 2 26th January 2005 04:59 PM
Copyright ©1999-2017 diyAudio
